Patch in place..... No, that did not cancel the compile error!
Here’s the code:
Thanks!Code:READTEMP: OWOUT PORTA.5,1,[$CC, $44] ' SEND Start Temperature Conversion command OWOUT PORTA.5,1,[$CC, $BE] ' SEND Read Temperature command OWIN PORTA.5,0,[STR dq\9] ' Retrieve all 9 bytes of data RawTemp.Byte0 = dq[0] RawTemp.byte1 = dq[1] IF RawTemp.8 = 1 then ' Check IF temperature is a negative reading SignC = Negative RawTemp.lowbyte = RawTemp.lowbyte ^ 255 ' Invert data ELSE SignC = Positive ENDIF dummy = RawTemp.0 ' Store the half degree indicator bit TempC = ((RawTemp.lowbyte) >> 1) * 100 ' Divide raw data by 2 to give real temperature TempC = TempC + (dummy * 50) ' Add the half degree is present IF SignC = Negative then ' Only proceed IF temperature is negative IF TempC => 1770 then SignF = Negative TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = TempF - 12200 RETURN ELSE SignF = Positive TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = 12200 - TempF RETURN ENDIF ENDIF SignF = Positive TempF = TempC * 18 / 10 + 3200 RETURN
