Read DS18S20
Results 1 to 17 of 17
Thread: Read DS18S20
    Dec 2007
    Hi skimask!
    Sorry, I’m somewhat confused here I don’t know what to believe in (of curse I believe in you!) since I also got a compilation error saying: “ERROR: Macro OWINSTR?W not found in macro file.”
    Huuh?
    Edit: Hey… it’s the other way around, it says 12-bits not supported! (found my glasses) :-) . Then (as usual) I must be doing something else wrong!
    Quote Originally Posted by PICante View Post
    The latest PBP update should fix that problem.
    If not, there's a thread somewhere around here relating a problem similar to that..somewhere...
    Edit: Hey… it’s the other way around, it says 14-bits not supported! (found my glasses) :-) . Then (as usual) I must be doing something else wrong!
    I don't know which manual you're reading.
    My manual says 12-bits aren't supported using the REP and STR modifiers. I'd tend to believe that due to the stack/ram constraints of 12 bit devices.
    Dec 2007
    Yes, my manual also says 12-bit. edited almost instantaneously! :-)
    I have got the P250a patch installed, can’t seem to find any newer?
    There's a b patch out now.
    Show the code...
    Dec 2007
    Smile
    I will try to find and run the patch to find out if that’s the culprit.
    Thanks ski
    Dec 2007
    Cool
    Patch in place..... No, that did not cancel the compile error!
    Here’s the code:
    READTEMP:
    OWOUT PORTA.5,1,[$CC, $44]                       ' SEND Start Temperature Conversion command
        OWOUT PORTA.5,1,[$CC, $BE]                   ' SEND Read Temperature command
        OWIN PORTA.5,0,[STR dq\9]                    ' Retrieve all 9 bytes of data
        RawTemp.Byte0 = dq[0]
        RawTemp.byte1 = dq[1]
        IF RawTemp.8 = 1 then                       ' Check IF temperature is a negative reading
            SignC = Negative
            RawTemp.lowbyte = RawTemp.lowbyte ^ 255               ' Invert data
            SignC = Positive
        dummy = RawTemp.0                                 ' Store the half degree indicator bit
        TempC = ((RawTemp.lowbyte) >> 1) * 100          ' Divide raw data by 2 to give real temperature
        TempC = TempC + (dummy * 50)                    ' Add the half degree is present
        IF SignC = Negative then                       ' Only proceed IF temperature is negative
            IF TempC => 1770 then
                SignF = Negative
                TempF = (TempC + 5000) * 900
                TempF = div32 500
                TempF = TempF - 12200
                SignF = Positive
                TempF = div32 500
                TempF = 12200 - TempF
        SignF = Positive
        TempF = TempC * 18 / 10 + 3200
    Thanks!
    Is not that much simpler than yout modifyer and the two following lines :
    ( taken from a Malc C example )
       OWIN    Porta.5, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]      ' Read two bytes / end comms
    I know that's not ALL of the code...
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  3. Replies: 13
    Last Post: - 12th May 2009, 17:26
  4. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  5. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
