Read DS18S20
Results 1 to 17 of 17
Thread: Read DS18S20
    Dec 2007
    Question Read DS18S20
    Hi all.
    Short time ago I found this code posted by CocaColaKid “ReadDS18S20” in this thread: http://www.picbasic.co.uk/forum/show...hlight=DS18S20
    Very neat I thought until I discovered that the STR function is not supported for 16FXXX, too bad. I have searched and found other pieces of code but they all seems to have a different approach to the task and I felt I could understand this code better. The PBP manual is not very helpful on OW and my question is what do I need to be change (and why) in this code to make it compile for the 16F688?
    Thanks!
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by PICante View Post
    Double check your manual...and compare what it says to the datasheet for the 16F688.
    'cause it looks to me like everybody in that other thread is using a 16Fxxxx series PIC and nobody is using an 18F.
    Dec 2007
    Hi skimask!
    Sorry, I’m somewhat confused here I don’t know what to believe in (of curse I believe in you!) since I also got a compilation error saying: “ERROR: Macro OWINSTR?W not found in macro file.”
    Huuh?
    Edit: Hey… it’s the other way around, it says 12-bits not supported! (found my glasses) :-) . Then (as usual) I must be doing something else wrong!
    skimask's Avatar
    skimask Guest
    The latest PBP update should fix that problem.
    If not, there's a thread somewhere around here relating a problem similar to that..somewhere...
    Edit: Hey… it’s the other way around, it says 14-bits not supported! (found my glasses) :-) . Then (as usual) I must be doing something else wrong!
    I don't know which manual you're reading.
    My manual says 12-bits aren't supported using the REP and STR modifiers. I'd tend to believe that due to the stack/ram constraints of 12 bit devices.
    Dec 2007
    Yes, my manual also says 12-bit. edited almost instantaneously! :-)
    I have got the P250a patch installed, can’t seem to find any newer?
    skimask's Avatar
    skimask Guest
    There's a b patch out now.
    Show the code...
    Dec 2007
    Smile
    I will try to find and run the patch to find out if that’s the culprit.
    Thanks ski
    Dec 2007
    Cool
    Patch in place..... No, that did not cancel the compile error!
    Here’s the code:
    READTEMP:
    OWOUT PORTA.5,1,[$CC, $44]                       ' SEND Start Temperature Conversion command
        OWOUT PORTA.5,1,[$CC, $BE]                   ' SEND Read Temperature command
        OWIN PORTA.5,0,[STR dq\9]                    ' Retrieve all 9 bytes of data
        RawTemp.Byte0 = dq[0]
        RawTemp.byte1 = dq[1]
        IF RawTemp.8 = 1 then                       ' Check IF temperature is a negative reading
            SignC = Negative
            RawTemp.lowbyte = RawTemp.lowbyte ^ 255               ' Invert data
            SignC = Positive
        dummy = RawTemp.0                                 ' Store the half degree indicator bit
        TempC = ((RawTemp.lowbyte) >> 1) * 100          ' Divide raw data by 2 to give real temperature
        TempC = TempC + (dummy * 50)                    ' Add the half degree is present
        IF SignC = Negative then                       ' Only proceed IF temperature is negative
            IF TempC => 1770 then
                SignF = Negative
                TempF = (TempC + 5000) * 900
                TempF = div32 500
                TempF = TempF - 12200
                SignF = Positive
                TempF = div32 500
                TempF = 12200 - TempF
        SignF = Positive
        TempF = TempC * 18 / 10 + 3200
    Thanks!
    Is not that much simpler than yout modifyer and the two following lines :
    ( taken from a Malc C example )
       OWIN    Porta.5, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]      ' Read two bytes / end comms
    Dec 2007
    Unhappy
    Hi Alain,
    Your suggestion tested, does not compile due to multiple errors in the line.
    Made a search in the forum but could not find anything regarding the STR macro problem.
    Thanks.
    skimask's Avatar
    skimask Guest
    I know that's not ALL of the code...
    Thumbs down
    I can't believe it ...
    I can't ...
    Dec 2007
    Talking
    You are correct; it’s not all the code. The rest of the code is working fine this is only going to be the part (subroutine) to measure temperature. And it’s also the part that does not compile.
    Thanks!
    Looks like you have dq defined as a WORD VS BYTE.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    skimask's Avatar
    skimask Guest
    Thanks!
    The rest of the code may very well be working fine, but the rest of the code also has any setup/initialization/interrupts that you are using, therefore, is just as important as the code that's messing up.
    I must be making this up as I go or something...
    We need to see how the variables are declared as well as other settings. Its obviously not this part of the code that is the culprit because it compiles fine for others which means there is a problem somewhere else in the code. Like Bruce said, it could be something simple like a word variable being declared as a byte.
    Dec 2007
    Red face
    Hi Guys!
    Been busy doing other stuff but now I’m back to finish this project! As some of you suspected it was a “simple” mistake, a word variable was declared as a byte! Now it runs like clockwork!
    It seems the problem is always simple, finding the problem is the hard part!
    Thank you all!
    Last Post: - 18th February 2010, 14:46
  2. Cleaning up code
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2009, 07:14
  3. Replies: 13
    Last Post: - 12th May 2009, 17:26
  4. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  5. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
