dWord variables
Results 1 to 8 of 8
Thread: dWord variables
    Default 24 bit memory addressing
    I am using the M25P128 memory chip which needs a 24 bit address. I use
    Addr0 var byte ' LSB of 24 bit address
    Addr1 var byte
    Addr2 var byte ' MSB of 24 bit address
    Every time Addr0 overflows I increment Addr1.
    Every time Addr1 overflows I increment Addr2.
    In my case I run Addr2 all the way up to FF. In your case Addr2 will only be 0 or 1.
    HTH
    BrianT
    xnihilo's Avatar
    xnihilo Guest
    Quote Originally Posted by BrianT View Post
    Addr1 var byte
    HTH
    BrianT
    Right. Thanks.
    I use address_low as a word var and address_high as a word var.
    When address_low overflows, it increments address_high by 1.
    I use a word var because with that I can increment this variable up to $FF.
    I think it should do the trick.
  1. Max Variables
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 04:05
  2. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  3. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 07:23
  4. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 14:36
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 18:37
