how to use the internal comparator in pic16f877a??
Results 1 to 12 of 12
    OMG... I wrote that SIX YEARS ago!!!
    Wink
    Hi, Mel
    I'm Aaaaabsolutely suuuuuure it's not you but your Elder sista ...
    regards
    Aug 2008
    thanx.i will work it out.if something goes wrong...i'll tell u guys...
    Aug 2008
    ' Device Programming Options
    @ DEVICE pic16F628, INTRC_OSC_NOCLKOUT
    ' System Clock Options
    @ DEVICE pic16F628, WDT_ON
    ' Watchdog Timer
    @ DEVICE pic16F628, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F628, MCLR_OFF
    ' Master Clear Options (Internal)
    @ DEVICE pic16F628, BOD_ON
    ' Brown-Out Detect
    @ DEVICE pic16F628, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F628, CPD_OFF
    ' Data Memory Code Protect
    @ DEVICE pic16F628, PROTECT_OFF
    ' Program Code Protection
    i can't compile if those code are exist.i use pic16f877a.
    Aug 2008
    @ DEVICE pic16F877a, INTRC_OSC_NOCLKOUT
    @ DEVICE pic16F877a, WDT_ON
    ' Watchdog Timer
    @ DEVICE pic16F877a, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F877a, MCLR_OFF
    @ DEVICE pic16F877a, BOD_ON
    ' Brown-Out Detect
    @ DEVICE pic16F877a, LVP_OFF
    @ DEVICE pic16F877a, CPD_OFF
    @ DEVICE pic16F877a, PROTECT_OFF
    BatVal var CMCON.7
    BatLoLED var PORTB.7
    CMCON=%00100101
    VRCON=%11101100
    Pauseus 10
    TRISA=%11111111
    TRISB=%00000000
    BatLoLoop:
    BatLoLED=BatVal
    Goto BatLoLoop
    my vref=4v, vin=3.6 and my vout=9v.can someone help me which part of the coding need to be edit.please...
    Vref = 4v - what is Vref connected to?
    Vin = 3.6v - what is Vin connected to?
    Vout = 9v - what is Vout connected to?
    Read the datasheet for the 16F877A!
    Can MCLR be turned off?
    How many oscillator modes does the 16F877A have? What are they?
    I Love the way you think Melanie . . .
    In a battery operated piece of equipment we need to detect when the
    batteries are getting low, so in turn we can switch on a 'Battery Low' LED
    to help flatten whats left of the battery even quicker... seems sensible to
    me....
    I wish more engineers thought as you do.
    Ranks right up there with....
    I'm almost out of gas so I'll drive to the nearest gas station even faster so I can run out of gas quicker so I can start walking even sooner!
    Aug 2008
    thanx everyone.it's work.but i have another problem that i can't solve.feel free to check my new thread...
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 14:58
  2. 12F683 internal pull up
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 27th July 2008, 02:35
  3. communicating pic18f452 with pic16f877a
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 13th July 2007, 19:54
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
  5. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
