asm interrupts
Results 1 to 12 of 12
Thread: asm interrupts
    Question asm interrupts
    Ok,
    I have been trying this for the last 2hrs. I think I am so frustrated that I am missing the obvious.
    I just want a free running 30ms interrupt using timer1. For whatever reason I have tried loading the timer with everything under the sun and no interrupt.....ggggrrrr. Someone please shed some light!
    ' chipbody: PIC16F877A
    INCLUDE "Modedefs.Bas"
    @ device HS_OSC, LVP_OFF, WDT_OFF
    ; @ Device pic16F877A, HS_OSC, BOD_OFF, PWRT_ON, WDT_ON, PROTECT_OFF
    DEFINE OSC 20
    ' Set Debugin pin port
    DEFINE DEBUGIN_REG PORTC
    DEFINE DEBUG_BAUD 4800
    ' Set Debugin pin bit
    DEFINE DEBUGIN_BIT 7
    ' Set Debugin mode: 0 = true, 1 = inverted
    DEFINE DEBUGIN_MODE 1
    DEFINE INTHAND myint
    ' Configure internal registers
    TRISD = %00000000
    TRISC = %00000000
    ' Initialize Interrupts
    TMR1L = $FE
    TMR1H = $FE
    T1CON = %00000001 ' $01 Turn on Timer1, prescaler = 1
    INTCON = %10000000 ' Enable global interrupts,
    PIE1 = %00000001 ' Enable TMR1 overflow interrupt
    Default Setting TMR1 for 24 mSecs
    I use a 'soft' interrupt by clearing the PIR1.0 register and preloading TMR1 to a value that gives me 24 mSecs. I start the timer routine and in my software I frequently check if PIR1.0 has been set by the TMR1 overflow. Being a code based 'check it when you can' the timing is a little flakey but it works fine in my application. I wanted to eliminate interrupt based code as far as possible since the overall timing can then get very hard to manage if interrupts get nested.
    I do run SWDTEN with a 58 mSec hard reset to keep things in line if the soft check of PIR1.0 should not work as expected.
    This is a snip from PIC16F88 code.
    MainLoop:
       'Housekeeping
       clearwdt
       WDTCON = %00001001 ' invoke s/w WDT, 58 mSec timeout,
    '   WDTCON = %00001010  ' has a recovery time about 110 mSec.
       OPTION_REG = %10001010  ' No wpu, prescaler assigned to WDT & /4
       INTCON = %00000000      ' disable all interrupts
       ANSEL =  %00000000      ' all digital
       CMCON  = %00000111      ' Comparators OFF to allow inputs on pins
       ADCON0 = %00000000
       ADCON1 = %00000000
       PIE1 = %00000001        ' enable TMR1 overflow interrupt
       PIE2 = %00000000
       PIR2 = %00000000
       TRISB = %11001111
       T1CON = %00100000       ' stop TMR1
       PIR1.0 = 0              ' clear bit 0 TMR1 interrupt flag
       TMR1H = $8C
       TMR1L = $A0             ' loads 36000 - gives 24 mS on CRO
       T1CON = %00100001       ' start TMR1
    FindSync:
    'high txd
       ' The exits from this loop are via TimeOut or 850 loops of steady '1'
       ' Noise should keep the program stuck in this block until timeout
       ' but it still finds occasional sync pattterns in pure noise
       if pir1.0 = 1 then timeout
       if radioppm = 0 then findsync
       ' RadioPPM has gone high here - check that it stays high
       ' A byte variable gives a loop time about 2.7 uSecs.
       ' A word variable loops in about 9.2 uS so there are less chances
       '  to detect a low spike during the sync period.
       for a = 0 to 255  ' measured at 2300 uS
          if radioppm = 0 then findsync ' noise or channel pulse
          if pir1.0 = 1 then timeout    ' been here too long
       next a
       for a = 0 to 255
       next a
       for a = 0 to 255
       next a
       for a = 0 to 200 '100
       next a
       if badch > 2 then timeout
       goto sendpacket ' 250 contiguous 1's - sync or stuck high
    TimeOut:  ' arrive here if TMR1 overflow is detected
              ' OR we were sent here by bad receive frame
       high txd 'low txd
       if pir1.0 = 0 then timeout ' wait until timer overflows
       'Strategy
       ' The failsafe values are predetermined by the FailCh[n] array.
       ' When a failsafe state is detected, the system slowly migrates from
       ' LastCh[n] count to the FailCh[n] count over a number of frames
       '  using FailLimit as the maximum increment or decrement
       high p1led
       failch[0] = 0     ' throttle - cut to zero
       failch[1] = 125   ' aileron - centralise
       failch[2] = 125   ' elevator - centralise
       failch[3] = 165   ' rudder - a small left rudder
       failch[4] = 125   ' gear - normally 30 or 220.  125 = failsafe
       failch[5] = 125   ' Aux 1
       failch[6] = 125   ' Aux 2
       failch[7] = 125   ' Aux 3
    HTH
    BrianT
    Unhappy still no interrupt
    I dropped in a segment of your configuration setup and still not even a simple toggle of an I/O port. I don't see the problem
    DEFINE OSC 20
    TRISD = %00000000
    TRISC = %00000000
    PIE2 = %00000000
    PIR2 = %00000000
    TMR1H = $8C
    wsave VAR BYTE $70 system ' Saves W
    ssave VAR BYTE bank0 system ' Saves STATUS
    psave VAR BYTE bank0 system ' Saves PCLATH
    fsave VAR BYTE bank0 system ' Saves FSR
    servo1 VAR byte bank0
    servo2 VAR byte bank0
    servo3 VAR byte bank0
    servo4 VAR byte bank0
    chksum1 var byte bank0
    chksum var byte bank0
    sv01 var byte bank0
    sv02 var byte bank0
    sv03 var byte bank0
    sv04 var byte bank0
    portc.0=0
    goto mainloop
    asm
    ; Save W, STATUS and PCLATH registers, if not done previously
    myint movwf wsave
    swapf STATUS, W
    clrf STATUS
    movwf ssave
    movf PCLATH, W
    movwf psave
    ; Save and restore FSR and any other registers used
    bCf portc.0
    movf 127,w
    movwf _servo1
    movwf _servo2
    movwf _servo3
    movwf _servo4
    ; Restore saved registers
    movf psave, W
    movwf PCLATH
    swapf ssave, W
    movwf STATUS
    swapf wsave, F
    swapf wsave, W
    retfie ; Return from interrupt
    endasm
    mainloop:
    portc.0=1
    goto mainloop
    I don't see anything clearing interrupt flag!
    I do clear it at the top. Do I have to clear it while inside the interrupt routine?
    Quote Originally Posted by Macgman2000 View Post
    Where do you clear the Timer 1 interrupt flag at the top?
    Refer to the PIC16F877A datasheet, DS39582B-page 26
    When interrupt fires it sets a flag bit and will not fire again until reset in ISR, that's The word according to my 3 bottles of Miller High Life anyway
    Default it works
    Got it working...I kept forgetting PIR1.0 and I was not re-loading tmr1H and tmr1L where needed in the code.
    Thanks all for the help!
    You got it!
    Check this:
    http://www.picbasic.co.uk/forum/show...ant+interrupts
    A bit of a steep learning curve, but once you get the hang of it, they're one of the better things since sliced bread... Makes dealing with 'true' interrupts a LOT easier...
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 14:45
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  5. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 19:21
