DS1307 problem
Results 1 to 4 of 4
Thread: DS1307 problem
    miniman's Avatar
    miniman Guest
    Default DS1307 problem
    I am just starting off with this project and am looking for the best option. What i have to do is, send a word across a 250 meter wireless link, receive it at the remote location, use a DS1307 to write the time to PIC16F877A using I2C, store to memory and send the information including the word and the time of the received information serially to a PC and display the result in Visual Basic 6.
    Can anyone give me a head start, relative websites, general advice etc etc.
    Thank you
    if you need some RF transmitters, LINX do some for cheap. They're also really nice and compact + really easy to use.
    here's the link
    http://www.linxtechnologies.com/inte...ction=products
    the above are available at DIGIKEY.
    also you have LAIPAC who made some good ones too... sure some are made by LINX...hum hum!!!
    http://www.laipac.com/
    Also one member here, Bruce (Reynolds Electronic), have some model in stock too.
    http://www.rentron.com/PicBasic/RemoteControl.htm
    he also provide some good example to work with those RF modules.
    http://www.rentron.com/remote.htm
    hope this help you.
    regards
    miniman's Avatar
    miniman Guest
    Default transceiver
    I have already chosen to use the ER400TRS transceiver as an acknowledgement has to be sent back to acknowledge that the data has been received.
    Another query is about the use of manchester encoding and how to implement an algorithm for this in C.
    have a look to this article
    http://www.quickbuilder.co.uk/qb/art...sing_RS232.pdf
    regards
  1. I2C eeprom and DS1307 @40MHz problem
    By ius01 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2007, 08:41
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 03:44
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
