serial out variable
Results 1 to 3 of 3
    Default serial out variable
    I am using the Melabs serial lcd 20 x 4 LCD, works great. I've been able to display text, but have searched the forum and can not find any tip or tricks to display the value of a variable so I can see what it is doing. Any suggestions? Thank you.
    Quote Originally Posted by tazntex View Post
    Since you're using a SERIAL LCD and you have to use the SEROUT command to get it to do anything, I think you answer is right there in the PBP manual under the SEROUT command. Look at the DEC, BIN, HEX modifiers...
    Your a genius Skimask, I read that part before but now it makes sense. Works great, thank you.
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. Replies: 33
    Last Post: - 19th March 2010, 04:02
  3. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  4. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  5. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
