Difference between modes in serial instructions
Results 1 to 2 of 2
    Iran
    Default Difference between modes in serial instructions
    Hi, what's the difference between modes in serial instructions such as serin and serout? what's the difference between (for example) T2400 and N2400 and OT2400 and ON2400? when i should use them and in which situation and for what applications?
    thank you
    T2400 is non inverted and N2400 is inverted. You use one of them when running thru an inverting levelshifter circuit such as the MAX232 and the other when you don't, for example.
    OT2400 is just like T2400 but the line isn't driven to the idling state, instead it's left floating (made an input). It can be usefull in multidrop networks.
  1. Replies: 33
    Last Post: - 19th March 2010, 04:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  5. Serious Serial Situation Setbacks...
