Addressing with Dip Switch or ???
Results 1 to 11 of 11
    May 2007
    You could store the Device ID (address) in EEPROM. As suggested by CocaColaKid, use ID 0 as the broadcast ID (every unit responds to this ID) to have the ability to change/add ID's. No need for switches, I/O's, etc. You can have up to 255 ID's - or if you use 2 bytes of EEPROM, up to 65535 ID's, if you should need that many.
    Thank you all for the tips. I will have to do some studying on the EEPROM, I have never used this.
    May 2007
    That is exactly what EEPROM is for - storage of configuration data, etc. The data is non-volatile, it is retained even if the PIC powered down, and is available on power-up. The 16F628A comes with 128 bytes of EEPROM built in. You now have 3 extra I/O pins available plus you save on the cost of the DIP switch and other components.
    See page 123 of the manual for the READ command, and Page 159 for the WRITE command to read/write EEPROM.
    Last edited by rmteo; - 15th September 2008 at 20:32. Reason: - added reference to manual.
    Thanks again.
    tazntex, Why not just use a 1 wire silicon serial number device from Maxim?
  1. Rotary Hex Dip Switch Code???
    By dangill in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 13:30
  2. DIP switch select delay
    By mongater in forum General
    Last Post: - 17th January 2008, 14:13
  3. Replies: 14
    Last Post: - 26th September 2007, 05:41
  4. dip switchs & inputs
    By grounded in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 13:37
  5. Newbie - 16F628A and switch latching
    Last Post: - 19th May 2006, 02:35
