Data and power over 2 lines
Results 1 to 11 of 11
    Sep 2007
    Waco, Texas
    Default data over DC lines....
    Bo-
    The app I am trying to work with is sending data over the phone lines when no call is active. Like you, my app does not really need to interface to anything over than whatever I come up with.
    I need to have bi-directional data go back and forth so I was working with superimposing AC over the DC on the phone line.
    I have not gotten very far with this yet.
    I would be interested in how you do to see if it may answer my problems.
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Dec 2005
    Before using the phone lines you need to do a bit of research. In most jurisdictions it's illegal to do as you propose. In the USA, you need to comply with FCC Part 68 rules.
    Sep 2007
    Waco, Texas
    Default Sorry, full disclosure
    Sorry-
    I am not working with the Ma Bell lines, just the lines after the phone switch. I need to get data to and retrieve data from an analog phone. Right now all I have is the pair of wires. If I can use the power from a non-inuse phone line and modulate the 48 VDC (which I am generating) I should be able to get data to and from the phone. The data will go to and from a PIC which will carry info about numbers called, time of day, etc.
    My fall back plan is to use another pair, feed DC to power everything and still modulate the DC. The second pair approach is much easier for me but much harder for a retro-fit.
    I am not folling with Miss Bells lines, otherwise I would be working from jail....... and getting a soldering iron would be tough .
    - Albert Einstein
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  2. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  3. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  4. Data on DC power lines?
    By boroko in forum Serial
    Last Post: - 21st February 2008, 16:34
  5. MAX1247 4-Channel, 12-Bit ADC
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2006, 00:38
