4 PWM output
Results 1 to 6 of 6
Thread: 4 PWM output
    Quote Originally Posted by Macgman2000 View Post
    which do you recommend?
    Recommend you learn how to use the Microchip Parametric search!
    http://www.microchip.com/ParamChartS...g=en&pageId=74
    Only 2 options available with 4 (or more PWM outputs)...
    Hint: PWM is part of the CCP module.
    Try it out and let us know what you find.
    If you get stuck, I'm not going anywhere for awhile...
    May 2007
    Smile
    If you select 2 CCP's and 3 ECCP's, you will find that there are 45 devices that have 5 PWM's.
    Touche`...I yield...
    If you further select 'In Production' and 5v devices, you get 12.
    I kind of like the new MAPS interface. (Microchip Advanced Parts Selector )
    http://www.microchip.com/maps/Microcontroller.aspx
    Un-check the 16 and 32-bit boxes first!
    Thanks all for the help!
    I noticed there are quite a few 24 series 16 bit mcu's with 5 PWM. Is PBP not going to support them soon? Anyone that would want the capability raise your hand
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. Microcontroller with 2 way paging application problem
  3. Serious Serial Situation Setbacks...
  4. 18F6585, PWM Output, which Pin?
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 26th April 2005, 22:37
  5. Using 4 input to control 10 output
    Last Post: - 5th November 2004, 13:08
