10f200 Icsp
Results 1 to 2 of 2
Thread: 10f200 Icsp
    Dec 2005
    Default 10f200 Icsp
    I want to use a PIC10F200 (SOT23) to supply a 50Hz or 60Hz squarewave to another embedded device. It will consist of just the PIC and bypass cap on a board that will plug into the other device using a 6P6C modular connector. ICSP should be straightforward but I'm confused by the second Vdd connection shown at the bottom of the ICSP diagram on p50 of the 10F200 datasheet. Can anybody explain it?
    Looks like the same Vdd to me. If you take out the programmer, it's just a MCLR pullup thru the resistor.
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 18:31
  2. ICSP from EPIC to Breadboard && 16f88
    By rdxbam in forum General
    Last Post: - 14th December 2008, 21:13
  3. what IS an ICSP connector?
    By mslaney in forum Schematics
    Last Post: - 5th March 2008, 08:05
  4. Replies: 1
    Last Post: - 11th December 2007, 00:57
  5. ICSP Programming from a PDA
    By Ralph in forum Off Topic
    Last Post: - 11th November 2007, 23:22
