DCC in PBP
Results 1 to 16 of 16
Thread: DCC in PBP
    malc-c's Avatar
    malc-c Guest
    Not sure if this is any help
    http://www.trainelectronics.com/miniDCC/index.htm
    It has some code and the site is about DCC
    Wink a nice one
    Hi, Boroko
    I found this tutorial ...
    In French, ... yes, FreeBasic, yes ... but everything needed explained .
    http://www.train35.com/dcc1.html
    And easy to port to pbP !
    Feb 2008
    Michigan, USA
    Thanks Alain for the suggestion. I will look and see what I can learn from there.
    Current plan is to use DT-Ints to capture and measure the width of the incoming pulses to determine weather they are short (58uS :"1") or long (100uS: "0") or standard AC power (16.7mS) and generate a level of 1 or 0 if it is data. If Std. AC I can jump to a fall-back and pick one of a few basic modes by cycling the power. The data pulses, once decoded, could be simply fed into the USART.
    Oct 2006
    Edmonton AB Canada
    Default DCC in PBP
    Bo, have a look at JMRI. Currently "decoders" which is the standard moniker for DCC assemblies that go into engines are run by pics. The latest crop have some interesting features, including "programmable" PWM. You can move the frequency range around to quiet noisy motors. It looks, programs and acts like NVRam. Quite cool, actually.
    Hope it helps
    Gary
    Feb 2008
    Michigan, USA
    Thanks Gary,
    From what I can tell, PICS have been used extensively in decoders. The specific issue that I'm trying to nail down is all of the code that I have seen is in assembly. I can muddle through assembly, but in this app, the timing is very tight, and I haven't mastered the skill to mimic the code in PBP. I have been refining the attack and will whittle away at it. I DON'T want to specifically duplicate the existing function, if so I could just burn the available .hex. I'm trying to accomplish comm over 2 wire in a similar way that is done in DCC. That's why I need to have control of the code.
    I appreciate all of the feedback that everyone has offered. It looks like I'll just have to upgrade my skill set a bit.
    Bo
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Extensions to PBP variables
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 06:21
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 04:16
