R/C receiver to PIC16F84
Results 1 to 10 of 10
    Quote Originally Posted by tech View Post
    Is it possible if u could send me the sample code of using Pulsin with the input from the receiver.
    I dont have an LCD to determine the value of the pulses coming through the receiver.
    [email protected]
    really appriciate it.
    Rohaimi
    Or...Or...Or...and I'm just going out on a limb here...You could read that other thread, forget the fact that you don't have an LCD and just ignore it, maybe even do something crazy like comment out anything to do with the LCD, write some code and do what you're going to do with the code, which you haven't said what your end result will be...But that's just me going out on a limb, ya know, trying something out for the first time...'cause that's just too funny...
    Wink
    Hi, Tech ( I do adore the joke ! )
    The good thing would be to know WHAT you want to do with the Rx decoded outputs ...
    cause channels capture code will depend upon that ...
    I think a search in these columns with "PULSIN" K.W. could give you lots of relevant hits ...subject is not "brand new" ... Lol !
    Apr 2007
    result1 var word
    result2 var word
    radio:
    pulsin PORTB.0,1,result1
    pulsin PORTB.1,1,result2
    if result1 < 600 then forward1
    if result1 > 900 then reverse1
    if result2 < 600 then ccw
    if result2 > 900 then cc
    goto radio
    Very sorry bout the previous post, just out it a side then.
    I've been trying the pulsin . Two channel go directly to the input.
    i.ve used this based on my previous school project using basic stamp. It was not programm by me. Did the order of programm goes in this way?
    comment appreciated.
    Wink
    Ok ...
    This is code obviously coming straight from a BS2 !!!
    1) you must tell PbP you work @ 20 Mhz ...
    DEFINE OSC 20 ... and use HS Oscillator
    2) as your channels follow each other, you must know you'll measure CH1, miss CH2, miss CH1, measure CH2, measure CH1, miss CH2, miss CH1 , measure CH2, etc, etc ...
    not very critical but you must know it for your timings ...
    3) Think CH1 and CH2 are refreshed every 20 - 25 ms ... and you'll have to update your captures ... so what do forward1,reverse1,ccw and cc subs must not take too long a time, to allow updating your channels at a "decent" rate ...
    4) may be you will have to add wrong pulses detection ... but it is another story !!!
    Apr 2007
    i get what u mean and had Define OSC 20 and the HC oscillator
    i dont get what u mean by the point below.
    How i measure CH1 and CH2? what u mean by "miss CH2"
    Takes to time to do what a PIC has to do according to your program.
    Therefore, if doing all of this thru software (i.e. not using any internal hardware modules), you'll spend time measuring the pulse width of CH1, then while acting upon that (driving another servo or something?), the PIC is too busy doing one thing to measure another pulsing (CH2).
    Wink
    Re,
    That's simple :
    The channel signals follow each others within ~ 10-15 ns ( nano seconds ! ) delay ...
    PULSIN need a little time ( some µs ) to be ready to catch the signal. (see PbP libs ! )
    those µs being more than the ns channel separation time, the second PULSIN doesn't see the second pulse rising edge ... and must wait for the following frame.
    That's all
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. 433 Mhz Data Receiver
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 29th November 2010, 03:26
  3. PBP code to read R/C signal from receiver
    Last Post: - 28th October 2009, 22:51
  4. Replies: 4
    Last Post: - 15th May 2008, 10:43
  5. receiver can not receive signal
    By nicolelawsc in forum Schematics
    Last Post: - 19th May 2006, 09:01
