R/C receiver to PIC16F84
Results 1 to 10 of 10
    Apr 2007
    Default R/C receiver to PIC16F84
    Im trying to hook up 2 channel R/C control system to pic16f84.
    How do i came out the programm to input the signal from the receiver to PIC?
    Do i use the Pulsin for this, need help, thanks?
    Oct 2003
    Australia
    I've successfully used Pulsin to count the servo pulses out of a receiver and then displayed on an LCD to show the servo movement. So I can say that this will work.
    This thread has good example of the bar graph http://www.picbasic.co.uk/forum/showthread.php?t=2359
    Squib
    Apr 2007
    Quote Originally Posted by Squibcakes View Post
    Squib
    Is it possible if u could send me the sample code of using Pulsin with the input from the receiver.
    I dont have an LCD to determine the value of the pulses coming through the receiver.
    [email protected]
    really appriciate it.
    Rohaimi
    Quote Originally Posted by tech View Post
    [email protected]
    Rohaimi
    Or...Or...Or...and I'm just going out on a limb here...You could read that other thread, forget the fact that you don't have an LCD and just ignore it, maybe even do something crazy like comment out anything to do with the LCD, write some code and do what you're going to do with the code, which you haven't said what your end result will be...But that's just me going out on a limb, ya know, trying something out for the first time...'cause that's just too funny...
    Wink
    Hi, Tech ( I do adore the joke ! )
    The good thing would be to know WHAT you want to do with the Rx decoded outputs ...
    cause channels capture code will depend upon that ...
    I think a search in these columns with "PULSIN" K.W. could give you lots of relevant hits ...subject is not "brand new" ... Lol !
    Apr 2007
    result1 var word
    result2 var word
    radio:
    pulsin PORTB.0,1,result1
    pulsin PORTB.1,1,result2
    if result1 < 600 then forward1
    if result1 > 900 then reverse1
    if result2 < 600 then ccw
    if result2 > 900 then cc
    goto radio
    Very sorry bout the previous post, just out it a side then.
    I've been trying the pulsin . Two channel go directly to the input.
    i.ve used this based on my previous school project using basic stamp. It was not programm by me. Did the order of programm goes in this way?
    comment appreciated.
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. 433 Mhz Data Receiver
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 29th November 2010, 03:26
  3. PBP code to read R/C signal from receiver
    Last Post: - 28th October 2009, 22:51
  4. Replies: 4
    Last Post: - 15th May 2008, 10:43
  5. receiver can not receive signal
    By nicolelawsc in forum Schematics
    Last Post: - 19th May 2006, 09:01
