how to generate triangular wave.....
Results 1 to 7 of 7
    Oct 2007
    The Netherlands
    use pwm, just ramp up and down with a counter and put a filter on the pin (RC).
    Aug 2008
    Thanks for ur quick response,
    i want fixed amplitude triangle wave of 2.5v,so how can i set a counter to generate the wave.
    Plz give me the required steps to do this.
    Raja.
    Oct 2007
    The Netherlands
    how about this as an example of a low frequency triangular wave:
    loop:
    for counter = 0 to 127
    hpwm 1,counter,10000
    pause 1
    next counter
    for counter = 127 to 0 step -1
    pause 1
    next counter
    goto loop
    Of course all in PBP, not assembly, but this is a PBP forum as you may have observed.
    Aug 2008
    Thanks,but i am using assembly language.
    Oct 2003
    holland
    Than you'v got the wrong forum.
    You will need the PIC_assembly forum and not one of the picbasic forum's.
    Quote Originally Posted by mat janssen View Post
    That's been said before...
    But somebody doesn't heed advice well...
    Not that assembly isn't spoken here obviously, but it's spoken so much more elsewhere.
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 14:39
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 04:31
  3. Generating 3-phase sine wave..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 15:07
  4. "Function Generator" Triangular Wave disturb
    Last Post: - 2nd June 2008, 18:38
  5. Data --> Modulated squre wave ???
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 27th August 2007, 04:18
