Multiple IR Receivers
Results 1 to 9 of 9
    Dec 2007
    Default Multiple IR Receivers
    Hello All,
    I am trying to get a PIC to receive a binary code from either one of two 38Khz IR receivers, at the moment it works for one receiver but i don't know how to make it monitor two pins? I think Interrupts are the way to go, but don't know where to start. Does anyone know how i could do this?
    <code>
    INCLUDE "modedefs.bas"
    CMCON = 7
    trisio = %00001111
    GPIO = 0
    DEFINE OSCCAL_1K 1 ' Set OSCCAL for 1K device
    Define OSC 4
    @ DEVICE PIC12f629, XT_OSC
    @ DEVICE PIC12f629, WDT_ON
    @ DEVICE PIC12f629, PWRT_ON
    @ DEVICE PIC12f629, MCLR_OFF
    @ DEVICE PIC12f629, BOD_ON
    @ DEVICE PIC12f629, CPD_OFF
    CODELENGTH VAR BYTE 'BYTE VARIABLE OK - LESS THAN 8 PULSES MEASURED
    UID VAR BYTE
    PIN VAR BYTE
    RXPIN1 Var GPIO.3
    Pause 100 'SETTLE DOWN BOTH PIC & IR RECEIVER
    STARTPULSE:
    PulsIn GPIO.3,0,CODELENGTH 'MEASURE LOW PULSE (IR LED ON TIME)
    IF (CODELENGTH > 200) and (CODELENGTH < 400) Then SENSOR1
    goto STARTPULSE
    SENSOR1:
    RXPIN1 = GPIO.3
    pin = 1
    GOTO CODEPULSES
    SENSOR2:
    RXPIN1 = GPIO.2
    pin = 2
    GOTO CODEPULSES
    CODEPULSES:
    PulsIn RXPIN1,0,CODELENGTH
    IF CODELENGTH > 150 Then LET UID.bit0 = 1 '2MS PULSE IS 1
    IF CODELENGTH < 150 Then LET UID.bit0 = 0 '1MS PULSE IS 0
    IF CODELENGTH > 150 Then LET UID.bit1 = 1
    IF CODELENGTH < 150 Then LET UID.bit1 = 0
    IF CODELENGTH > 150 Then LET UID.bit2 = 1
    IF CODELENGTH < 150 Then LET UID.bit2 = 0
    IF CODELENGTH > 150 Then LET UID.bit3 = 1
    IF CODELENGTH < 150 Then LET UID.bit3 = 0
    IF CODELENGTH > 150 Then LET UID.bit4 = 1
    IF CODELENGTH < 150 Then LET UID.bit4 = 0
    IF CODELENGTH > 150 Then LET UID.bit5 = 1
    IF CODELENGTH < 150 Then LET UID.bit5 = 0
    IF CODELENGTH > 150 Then LET UID.bit6 = 1
    IF CODELENGTH < 150 Then LET UID.bit6 = 0
    IF CODELENGTH > 150 Then LET UID.bit7 = 1
    IF CODELENGTH < 150 Then LET UID.bit7 = 0
    IF UID = 247 Then LEDON
    codelength = 0
    UID = 0
    GoTo STARTPULSE
    LEDON:
    High GPIO.0 'LED ON
    serout 1, N2400,[#PIN," ",#UID,10,13]
    Pause 500
    Low GPIO.0
    codelength = 0
    UID = 0
    GoTo STARTPULSE
    </code>
    Thank in advance,
    Jeremy
    It may be reading one, then executing the GOTO and then continues
    to execute below the if thens and repeats at the GoTo STARTPULSE.
    I would make the GOTOs into gosubs with returns, so the code will return
    to the next line which is the next sensor.
    CMCON = 7
    trisio = %00001111
    GPIO = 0
    Define OSC 4
    UID VAR BYTE
    PIN VAR BYTE
    RXPIN1 Var GPIO.3
    STARTPULSE:
    goto STARTPULSE
    SENSOR1:
    RXPIN1 = GPIO.3
    pin = 1
    GOSUB CODEPULSES
    SENSOR2:
    RXPIN1 = GPIO.2
    pin = 2
    GOSUB CODEPULSES
    CODEPULSES:
    IF UID = 247 Then
     GOSUB LEDON
    codelength = 0
    UID = 0
    GoTo STARTPULSE
    LEDON:
    High GPIO.0 'LED ON
    Pause 500
    Low GPIO.0
    codelength = 0
    UID = 0
    GoTo STARTPULSE
    These modules have a weak internal pullup, so simply connecting the outputs of both modules to a single pic pin should work.
    Anand
    Dec 2007
    Hi Guys,
    What i am trying to do is have the signals come in on different pins and then send the received data along with the input pin number out through RS232. I have tried using GOTO and GOSUBS commands but it only works 50% of the time on one pin and not at all on the other.
    Thanks Guys
    Quote Originally Posted by jhorsburgh View Post
    Hi Guys,
    Thanks Guys
    Are you saying that because one pin is tied up looking for a pulse that it ends up missing pulses on the other pin?
    Not sure if it'll help any (probably won't since a PIC is single threaded and can only act on one input at any one time unless you record any pulses you get and post-process them to see if anything useful was present during the time you recorded any pulses), but if you check your manual, you might find something that'll help you limit the MAXIMUM time the PULSIN statement waits for a PULSE (quite a few hints in that statement right there).
    Dec 2005
    Why are you using two receivers? If both are 38kHz, both will see both signals. Whichever pin is triggered first will seize control.
    Dec 2007
    Hey Guys,
    I had made the following changes to the code, and added the "DEFINE PULSIN_MAX 300" line to the top of the code. It now works for GPIO.3 most of the time but it does not work at all on GPIO.2. The modules are 38Khz dave but i am not sure what you mean by "both will see both signals. Whichever pin is triggered first will seize control. "
    <code>
    STARTPULSE:
    PulsIn GPIO.2,0,CODELENGTH 'MEASURE LOW PULSE (IR LED ON TIME)
    IF (CODELENGTH > 200) and (CODELENGTH < 400) Then SENSOR2
    goto STARTPULSE
    SENSOR1:
    RXPIN1 = GPIO.3
    pin = 1
    GOTO CODEPULSES
    SENSOR2:
    RXPIN1 = GPIO.2
    pin = 2
    GOTO CODEPULSES
    </code>
    Thanks Again,
    Jeremy
    Place PulsIn GPIO.2,0,CODELENGTH before PulsIn GPIO.3,0,CODELENGTH.
    Does it work with the sensor on GPIO.2 now?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2005
    Unless the two receivers are optically isolated so that neither can see the signal intended for the other, both will see all signals.
    The first one in your code will process the signal, blocking all of the code statements for the other one.
    If you follow Bruce's suggestion, the one that wasn't working will start working but the other will stop working.
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 08:44
  3. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 11:40
  4. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 17:12
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 22:07
