Slave PIC to be used like CD4021 chip
Results 1 to 18 of 18
    Simply treat the 64/65 bit buffer as a Byte or Word Array... Shift it out using the pointers I've given you here...
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    I was just trying to visualize what it would take ...
    But it seems to have turned into a whole program.
    And yup, it uses Melanie's suggestions.
    The idea here is to continuously scan the A/D inputs, saving the results to a buffer array.
    When it gets a Parallel Load signal (INT), it copies the buffer to the "Shift" array.
    Instead of taking the time to actually shift everything each time, it uses an Index counting down from 63 to put each bit out on the pin.
    Each bit that is sent, gets replaced with the Input Bit. After it's finished sending all 64 bits, it wraps around and is now sending the data that was shifted IN like a big circular buffer.
    It's written for a 16F883, because it has 8+ A/D inputs and an internal 8mhz OSC, but it should work on other chips too (after changing a few things).
    I do not have a 16F883, or a CD4021, so this is completely untested.
    It does compile, and I think it's close. Should at least be a good starting point.
    '*  Name    : Shift4021.pbp                                     *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 9/9/2008                                          *
    '*  Notes   : Target = 16F883, Internal 8mhz OSC                *
    '*  Thread  : Slave PIC to be used like CD4021 chip             *
    '*     http://www.picbasic.co.uk/forum/showthread.php?t=9544    *
    @    __config _CONFIG1, _INTOSCIO & _WDT_OFF & _LVP_OFF & _CPD_OFF
    DEFINE OSC 8
    Clear
    PloadPin  VAR PORTB.0      ; Parallel Load (INT)
    ClkPin    VAR PORTB.1      ; Serial Clock
    SerInPin  VAR PORTB.2      ; Serial Input Pin
    SerOutPin VAR PORTB.3      ; Serial Output Pin
    ADbuff    VAR BYTE[8]      ; Buffers the A/D readings
    ShiftReg  VAR BYTE[8]      ; The 64-bit shift register
    I         VAR BYTE         ; Index variables
    X         VAR BYTE
    BitIdx    VAR BYTE
    ADidx     VAR BYTE
    ClkState  VAR BIT          ; for locating clk edges
    DataBit   VAR BIT          ; Serial In read on falling edge
    INTE      VAR INTCON.4     ; Aliases
    INTF      VAR INTCON.1
    GoDone    VAR ADCON0.1
    Initialize:
        OSCCON = %01110001         ; Internal 8Mhz OSC
        INPUT PloadPin             ; Input(default), just to make sure
        INPUT ClkPin
        INPUT SerInPin
        LOW   SerOutPin            ; start with output LOW
        ADCON0 = %10000001         ; FOSC/32, CH0, ADON
        ANSELH = 0                 ; Turn off upper A/D ports
        INTF = 0                   ; clear INT flag
        INTE = 1                   ; enable INT interrupt
        ON INTERRUPT goto ParallelLoad
        if !GoDone then NextAD     ; conversion complete, get results
        IF ClkPin then             ; wait for Rising edge
            if !ClkState then
                ClkState = 1
                GOSUB NextBit      ;   Rising edge found, shift data
        else                       ; wait for falling edge
            if ClkState then
                ClkState = 0
                DataBit = SerInPin ;   falling edge found, read input
    GOTO Main
    ; ---- Cycle thru each A/D channel, one at a time --------------------------
    NextAD:
        ADbuff(ADidx) = ADRESH             ; save A/D result
        ADidx = ADidx + 1                  ; point to next A/D channel
        if ADidx = 8 then ADidx = 0        ; circle around
        ADCON0 = %10000001 | (ADidx << 2)  ; Set the A/D ch.
        for I = 1 to 5                     ; Acquisition time
            @ NOP
        NEXT I
        GoDone = 1                         ; Start A/D conversion
    DISABLE
    ; ---- Parallel Load -- copy A/D buffer to Shift register ------------------
    ParallelLoad:
        For X = 0 to 7                     ; Copy A/D results
            ShiftReg(X) = ADbuff(X)
        NEXT X
        SerOutPin = ShiftReg.0(63)         ; put MSB on Pin
        BitIdx = 63                        ; start shifting from MSB
        DataBit = SerInPin                 ; read input bit
        INTF = 0                           ; clear the interrupt flag
    RESUME
    ; ---- Put next bit on the output pin --------------------------------------
    NextBit:
        ShiftReg.0(BitIdx) = DataBit        ; replace bit with the input data
        BitIdx = BitIdx - 1                 ; point to next bit
        if BitIdx.7 = 1 then BitIdx = 63    ; circle back to beginning
        SerOutPin = ShiftReg.0(BitIdx)      ; put data on output Pin
    HTH,
    Last edited by Darrel Taylor; - 10th September 2008 at 12:00. Reason: added ANSELH = 0, and X looop var
    Thank you all for the tips. Well, Darrel, it is more than a starting point. It is almost done! Thanks a lot. Also, yes 64 bit is OK. I stuck on 65 for some reason...
    Soon I will post the results.
    Exclamation
    Just made a couple changes. I used the same loop var in the interrupt handler. DOH!
    Changed it to X, was I.
    Also turned off the upper A/D ports.
    ANSELH = 0
    2 less bugs anyways.
    One more bug. On the main the first If/Then needs a gosub.
    I have to admit that your writing style is very clever. Especially I liked the handling of AD inputs with the OR statement. Very clever indeed!
    Thanks again!
    Edit: Another bug would be the channel selection of A/D module. Since the 883 does not have 5,6 and 7 channel available, it cannot be used as it is the program. Of course it works as is for the bigger cousins 884 and 887.
    Ahhh, yes it does. Good catch.
    DOH!
    I wish they'd make the datasheets individually. A separate one for each of the 882/883/884/886/887. Instead of jamming a whole series in one sheet so you have to pick out the differences on your own.
    OK, there's still more than 8 A/D's in there, I'll have to find a workaround.
    Unless you beat me to it.
    Default Update
    Moved pins away from the RB1 - RB3 (AN8 - AN10).
    Added GOSUB you found.
    Modified A/D channel selection.
    Sure wish I had one of these chips. BTW, will you be using a different chip?
    '*  Version : 1.1                                               *
    DEFINE OSC 8
    Clear
    ClkPin    VAR PORTB.4      ; Serial Clock
    SerInPin  VAR PORTB.5      ; Serial Input Pin
    SerOutPin VAR PORTB.6      ; Serial Output Pin
    X         VAR BYTE
    BitIdx    VAR BYTE
    ADidx     VAR BYTE
    ADchannel VAR BYTE         ; Actual AD ch being used (5,6,7 missing)
    INTF      VAR INTCON.1
    GoDone    VAR ADCON0.1
    Initialize:
        INPUT ClkPin
        INPUT SerInPin
        ANSELH = %00000111         ; Turn off upper A/D ports (8,9,10 used)
        if !GoDone then GOSUB NextAD   ; conversion complete, get results
            if !ClkState then
                ClkState = 1
            if ClkState then
                ClkState = 0
    GOTO Main
    NextAD:
        ADchannel = ADidx
        if ADidx > 4 then
            ADchannel = ADchannel + 3      ; correct for missing AN 5,6,7
        ADCON0 = %10000001 | (ADchannel << 2)  ; Set the A/D ch.
            @ NOP
        NEXT I
    DISABLE
    ParallelLoad:
        NEXT X
    RESUME
    NextBit:
  1. ShiftOut. Using PIC as Slave device.
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 16th March 2010, 20:10
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  3. Camera with PIC chip
    Last Post: - 1st July 2008, 15:28
  4. PIC chip resetting. Very weird
    Last Post: - 28th October 2007, 18:07
  5. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 20:26
