problem with PWM
Results 1 to 4 of 4
    Mar 2007
    thanx skimax!
    with further investigation i have made a hardware pwm that sets in the background!
    here is the code if anyone needs it
    INCLUDE "MODEDEFS.BAS"
    ' ** Declare Variables **
    Pause 500
    start:
    IF PORTB.7=1 Then
    TRISC.2 = 0 ' Enable PORTC.2 (CCP1) as output for PWM
    T2CON = %00000100 ' Set the Prescaler for 1:1, and turn on TMR2
    PR2 = 255 ' See above calculation for the output period
    CCPR1L = 128 ' MSB of the 10-bit duty value
    CCP1CON.2 = 1 ' Turn on PWM Module one,
    CCP1CON.3 = 1 ' by setting bits 2 and 3 of CCP1CON
    EndIF
    IF PORTB.7=0 Then
    CCPR1L = 0
    High PORTB.6
    EndIF
    GoTo start
    Quote Originally Posted by mimmmis View Post
    thanx skimax!
    Or you could just use the HPWM command...
  1. Low freq PWM problem
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 17th February 2010, 08:09
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 19:43
  4. Problem with PWM using 16F688
    By electrocomp in forum General
    Last Post: - 1st December 2007, 15:14
  5. PWM problem CCP2 port
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 20th September 2006, 00:34
