problem with PWM
Results 1 to 4 of 4
    Mar 2007
    Angry problem with PWM
    Hi i made a connection computer-->rs232-->pic16f876. it works fine. then i connected an h-bridge and a dc motor to my pic. it works fine. with 1 it moves counterclockwise with 2 clockwise and with 0 it rests.my program
    INCLUDE "MODEDEFS.BAS"
    B0 VAR WORD
    B1 VAR WORD
    Pause 500
    SerOut2 PORTC.6,84,["Hi!",13,10]
    start:
    SerIn2 PORTC.7,84,[DEC B0]
    IF(B0==1) Then
    Low PORTC.1
    High PORTC.2
    EndIF
    IF(B0==0) Then
    Low PORTC.1
    Low PORTC.2
    EndIF
    IF(B0==2) Then
    Low PORTC.2
    High PORTC.1
    EndIF
    GoTo start
    I have to problems:
    first i want to put some different levels of speed.
    so i wrote the following program but it works as the first program!with numbers 3 and 4 i can't see reduce in speed.
    B0 VAR WORD
    B1 VAR WORD
    Pause 500
    start:
    IF(B0==1) Then
    Low PORTC.1
    High PORTC.2
    EndIF
    IF(B0==0) Then
    Low PORTC.1
    Low PORTC.2
    EndIF
    IF(B0==2) Then
    Low PORTC.2
    High PORTC.1
    EndIF
    IF (B0==3) Then
    Low PORTC.2
    PWM PORTC.1,128,10
    EndIF
    IF (B0==4) Then
    Low PORTC.2
    PWM PORTC.1,64,10
    EndIF
    GoTo start
    SECONDLY i want the motor dc to run in the speed i say until a new press from my keyboard.do i need harware pwms? i need 4 (=2 motors). is there a pic with 4 pwms?
    Thanx in advance
    PWM is a 'blocking' command, synchronous, one-at-a-time...
    While a PWM command is executing, nothing else can run. PWM is software driven, bit-banged, etc.
    HPWM on the other hand is hardware driven. Set the registers and it runs without further program intervention, aside from changing the frequency and/or duty cycle.
    Mar 2007
    thanx skimax!
    with further investigation i have made a hardware pwm that sets in the background!
    here is the code if anyone needs it
    ' ** Declare Variables **
    Pause 500
    start:
    IF PORTB.7=1 Then
    TRISC.2 = 0 ' Enable PORTC.2 (CCP1) as output for PWM
    T2CON = %00000100 ' Set the Prescaler for 1:1, and turn on TMR2
    PR2 = 255 ' See above calculation for the output period
    CCPR1L = 128 ' MSB of the 10-bit duty value
    CCP1CON.2 = 1 ' Turn on PWM Module one,
    CCP1CON.3 = 1 ' by setting bits 2 and 3 of CCP1CON
    EndIF
    IF PORTB.7=0 Then
    CCPR1L = 0
    High PORTB.6
    EndIF
    GoTo start
    Quote Originally Posted by mimmmis View Post
    thanx skimax!
    Or you could just use the HPWM command...
  1. Low freq PWM problem
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 17th February 2010, 08:09
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 19:43
  4. Problem with PWM using 16F688
    By electrocomp in forum General
    Last Post: - 1st December 2007, 15:14
  5. PWM problem CCP2 port
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 20th September 2006, 00:34
