I haven't been able to get simple transmit of a high pin state working yet so i'm going to wait for serial data until that works. but thanks for the code anyway.
Yes, that is the antenna as it came prewired from the factory.
Transmitter / Receiver works fine until it's hooked up to the PIC so the antenna must be at least somewhat close. Perhaps it's a 1/2λ antenna?
I usually work with the receiving end on the other side of the room (15 ft away).
I've been reading other threads where people are suggested to try lower clock frequency on their PIC's, buffering the outputs of the PIC and hooking up comparators. I have none of these options available and would like to know if they actually have helped before I order more parts.
