help
Results 1 to 5 of 5
Thread: help
    Jan 2008
    Default help
    how the command is read by the mcu?
    <code>
    ;config
    portb = 0
    start:
    pulsout portb.0,175
    pulsout portb.2,185
    pulsout portb.1,170
    pulsout portb.3,130
    pulsout portb.6,150
    </code>
    I tested this in my bipedal robot and it not follow the first command? how command are read by the mcu?
    You posted this before and would not work with the person trying to help you, a second post will do no better.
    http://www.picbasic.co.uk/forum/showthread.php?t=1742
    skimask's Avatar
    skimask Guest
    http://www.picbasic.co.uk/forum/show...73&postcount=3
    http://www.picbasic.co.uk/forum/show...17&postcount=3
    My car won't start. Why not?
    See how generic that statement/question is?
    You probably couldn't help me with my car if you wanted to.
    By the same token, without more information from you, the population in general, probably couldn't help you if they wanted to.
    See the relationship yet?
    Aug 2008
    Yeah, please provide more info. I think you need to insert a delay after portb = 0.
    Wink
    No chance for it to work as is :
    reason is simple, Pulses must be sent every 20-25 ms for the servos to keep their positions ...
    so, try ( for the "functionnal part" ) :
    [code]
    ;config
    portb = 0
    start:
    While 1
    pulsout portb.0,175
    pulsout portb.2,185
    pulsout portb.1,170
    pulsout portb.3,130
    pulsout portb.6,150
    PAUSE 15
    Wend
    Now ... if it is BI pedal ... might not the pulsouts used be in an even count ???
    PS : Ski pointed you'll have a lot to learn ... and I DO AGREE.
    So, try to listen ... he's one of the best you can find here !!!
