Connecting programmer to MicroCode Studio
Results 1 to 34 of 34
    Default Installing the PICkit2 Command Line Interface
    Download the latest PICkit2 GUI, and the "PICKit2 Command Line Interface" from Microchip.
    http://www.microchip.com/stellent/id...cName=en023805
    Extract all files from PK2CMD to your "C:\Program Files\Microchip\PICkit 2 v2" folder.
    It's the same folder as the PICkit2 programmer software.
    In Microcode Studio View | Compile and Program Options... | programmer tab,
    click Add New Programmer, select "Create a custom programmer entry" then click "Next".
    Enter any name you wish to call it and click "Next".
    Enter pk2cmd.exe as the "Programmer Filename" and click "Next".
    Click the "Find Manually" button and point it to C:\Program Files\Microchip\PICkit 2 v2 and click "Next".
    Enter this parameter line
    -pPIC$target-device$ -f$hex-filename$ -M -R -T -h2
    Then click Finished.
    Pressing Compile and Program or F10 in MicroCode Studio will now do it all.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3146" /><!-- Name:  PicKit2_CMD.JPG
Size:  120.3 KB -->
    Descriptions of those, and additional command-line parameters can be found in the "Readme For PK2CMD.txt" file from the .zip above.
    Dec 2003
    San Diego
    Default PICkit2?
    Darrel,
    I set up my programmer as you directed and still get the same results...
    The PICkit2 application starts and and just shows that it found the connected PIC... thats all. I have to manually click the putton and then select the hex to get it to program the target PIC.
    Just before the application starts the programmer shows activity but that is maybe just reading the target PIC to confirm a connection.
    I tried many of the other commands in the readme file with no luck.
    It looks like the command never actually runs or has some other error.
    The PICkit2 application gets started from the programmer path you enter in the IDE so its the script that is not working.
    My new USB U2 came today and it works with the script... so I guess I will scrap the PICkit... too bad the price is right and it does work if manually directed. It also works as stand alone.
    Maybe MEL has some other info on how to get the PICkit2 to work with the script.
    Are you sure you entered pk2cmd.exe as the Programmer Filename.
    It opens a DOS window, not the PICkit2 GUI program.
    If it's opening the GUI, something's definitely not right.
    Jun 2008
    Varese , Italy
    Default programmer launch from Microcodestudio
    Hi to you all !
    I do have to launch the MPLAB in order to programm the PIC directly from the MCS. At the moment I use the MCS and MPASM and then i call the MPLAB to program the chip. I will like to do it in a single action.
    Thanks for any suggestion .
    Ambrogio
    IW2FVO
    North Italy
    May 2007
    See posts #8,12,14,17.
    Dec 2003
    San Diego
    Default PICkit2?
    Darrel,
    I changed the programmer exe and now I get a dos window for a short instant... then it goes away... It is so fast that I cnnot see anything in the window.... programmer does nothing and target PIC is not read or programmed.
    So...the dos is starting but not reading any script.
    Are you actually using the script and one click programming from the IDE?
    I have configured my IDE to place my compiled code in the PICkit2 folder.
    The -h2 parameter causes it to pause for 2 seconds before closing the window.
    But since you didn't do the "Programmer Filename" step, I assume you didn't do the parameters either.
    What I showed above was a series of steps that must be completed for it to work. ALL steps must be completed exactly as shown. Miss one, it won't work.
    Not sure how you did that. As far as I know, that's not an option in Microcode Studio.
    You can set the default folder that comes up for a File|Save, but if you're saving everything in your PICkit2 folder, that's just plain silly.
  1. Connecting PICSTART to Microcode Studio
    By OzGrant in forum General
    Last Post: - 2nd February 2010, 10:20
  2. Connecting PICSTART to Microcode Studio
    Last Post: - 30th January 2010, 20:40
  3. Microcode studio programmer question
    By zk_bamx2 in forum mel PIC BASIC Pro
    Last Post: - 4th February 2008, 10:20
  4. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 01:18
  5. Replies: 2
    Last Post: - 25th February 2006, 02:53
