Code Executing Slow
Results 1 to 6 of 6
    Aug 2008
    Default Code Executing Slow
    Hi all....
    I have taken over a project from someone else who was using a different programmer than me. Same code, but when I program it the code executes VERY...VERY slow... any thoughts??
    The code works fine, just it is in like slow motion....
    Hello Frozen001,
    Without seeing the code, or knowing the PIC you are using . . .
    Probably the main OSC is not working, and it is running on backup OSC I. E. FSCM
    Fail Safe Clock Monitor, likely your friends code has no config fuses set and they did that manually in the programmer
    Aug 2008
    Hello Frozen001,
    The PIC is an 18F8722, with a 20MHz external clock...
    When I got the circuit card, the code was programmed on the PIC. I took the exact code on the chip, changed what was displayed on a display, adn programmed the PIC. Ever since then it is in slow motion...
    Quote Originally Posted by Frozen001 View Post
    I don't think the config fuses are going to be recovered from the hex when you read a chip, though I might be wrong. In using ICPROG it has available the option to set the fuses in the programmer, if the chip doesn't know about the EXT. OSC, it will run on what it finds inside, again FSCM . . . , have you verified the ext. OSC is working ?
    Aug 2008
    I figured it out, the oscilator type in the include file was set wrong on my end.
    I thought it was using a copy of the file in the local directory instead of the one in the path...
    Is there a way to ensure the compilier uses local copies rather than the ones in the path?
    I always put the Config settings in my source code, the compiler appends it to the hex and it is set for you when you open the file in the programmer.
  1. Slow code needs a tune up
    Last Post: - 5th January 2010, 16:05
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
