Conversion to degrees help
Results 1 to 19 of 19
    Thank you for your fast reply
    yes you are right, So 360 / 4096 = 0.087 deg
    The linearity is ok as it is an absolute magnetic encoder
    I would like to display the result on an LCD in a xxx.xx format or xxx.xxx
    even if it does not reach its final resolution and the last digits are not correct or rounded
    Any help welcome
    Walter
    thank you joe, but value's are getting to big to fit in a 16bit var
    I thnk I need help from the Mathematics guy's
    Quote Originally Posted by RFsolution View Post
    That is most positively not me
    Post a little code and an example of the values you are getting.
    And maybe think about upgrading to 2.5. The LONGS are cool.
    Thanks Dave,
    Can you point me how to use the LONGS because when reading the PBP manual (online version and PDF @ melabs) they say 16bit is the maximum
    If i try to compile more than 16bit it give's me an error (i upgraded to 250.B and use MPASM)
    Are we talking about the same PICbasic ? I use Picbasic PRO from melabs
    Yes, we are talking about the same PBP. The online version of the manual is a few versions old.
    At the risk of saying you have an illegal copy, where is the printed manual you got when you upgraded?
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 16:26
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 18:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 18:20
  5. 16bit variable and degrees conversion
    Last Post: - 2nd May 2005, 17:27
