Pic18f4455
Results 1 to 5 of 5
Thread: Pic18f4455
    Mar 2007
    Cool Pic18f4455
    Hello,
    how can I set configuration bit for Low Voltage Program that my RB5 is I/O (not PGM) for my PIC18F4455, I can not find it in .INC file, (I use assembly language).
    thanks
    Look in the P18F4455.inc file in your MPASM directory. There's a list of all config options.
    New way;
    ; Single-Supply ICSP Enable bit:
    LVP = OFF Single-Supply ICSP disabled
    LVP = ON Single-Supply ICSP enabled
    Old way;
    _LVP_OFF_4L EQU H'FB' ; Single-Supply ICSP disabled
    _LVP_ON_4L EQU H'FF' ; Single-Supply ICSP enabled
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2007
    Hello Bruce,
    thank you for your advice, I have overlooked it in .INC file. It is OK now.
    Can you tell me please, for PIC18F4455, can I turn off SPP0, SPP1, SPP2 and SPP3 with configuration bits or I have to do it on some other way?
    thanks
    Read the section on Streaming Parallel Port in the data sheet. If that doesn't answer your
    question let me know....;o}
    -Bruce
    tech at rentron.com
    Mar 2007
    Hello Bruce,
    I have found it, thanks for advice,
    regards
  1. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  2. Pic18F4455 to PC communication RS232
    By anmproj in forum mel PIC BASIC Pro
    Last Post: - 30th July 2005, 03:32
