Circuitry design
Results 1 to 10 of 10
    Sep 2008
    Default Circuitry design
    I have a circuitry with 3 servo motors + pic.
    I am using two parallel 7805 for the motors and one only for the pic.
    Unfortunately I found that a choppy servo motor behaviour is due to not enough current being delivered - ie I am working with interrupts so two servos need current at the same time.
    I found that one (of the parallel) 7805 remains cold while the other one is becoming very hot.
    Should there be one 7805 for each motor + one for the pic, ie 4x7805 or should my current configuration be sufficient but one 7805 is faulty or some other solution?
    Maximum current per 7805 is 1A accord. to the data sheet.
    This is easier than getting the load balanced between multiple 7805 regulators.
    http://www.national.com/mpf/LM/LM350.html
    3 amps with heat sink.
    Use the LM350 for the motors and a 7805 for the PIC.
    If you still want to parallel the 7805s, bend the legs so one heat sink can be attached to all of them at the same time (chips side by side) . The legs should be bent enough to allow at least 0.20 inch traces on all legs. Do not use a set of capacitors for each regulator. Put together as stated and you have one big regulator.
    Or you have a bad 7805.
    Wink
    Hi Security,
    You also can use a PNP Ballast to boost the 7805 regulator output ...
    See National Datasheets ( Lm 317,350,338 ) AND MC78xx Datasheets for such info.
    Do not forget to use a Large value Low ESR capacitor to allow current "surges" ...
    Sep 2008
    As both 7805 are parallel does that mean I can just replace one of them with a LM350 and remove the other one?
    Yes, one 350 will take the load of two 7805s. The pin out is different and you need external resistors to set the voltage of the 350 because it is adjustable, so it is not a direct replacement on a PCB.
    Sep 2008
    I prefer to not redesign my current circuitry. What about other components doing the trick fitting in the position of my 7805?
    PS: If I actually had to redesign my circuitry I would use http://www.elecfree.com/electronic/5...ly-by-tip2955/.
    Quote Originally Posted by Security View Post
    Yep, that would work to. Just like Alan suggested.
  1. Propeller Clock Advanced Design
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 21st June 2022, 21:38
  2. how large and complex firmware you design using pbp?
    By chrdcv in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2008, 01:30
  3. PIC16F88 senior design
    By AlaskanEE in forum Serial
    Last Post: - 2nd May 2007, 15:06
  4. need advice on selling my design
    By nimonia in forum Off Topic
    Last Post: - 3rd March 2007, 00:27
  5. PCB Design Partnership Enquiry;
    By arbel in forum Adverts
    Last Post: - 15th February 2007, 09:07
