Dialer schematic
Results 1 to 11 of 11
    Ground is pin#3 com is pin#1
    I think COM is the other half of the signal to drive the transformer.
    From the data sheet
    Common Input Pin. Biased internally at mid-supply.
    Just a guess.
    Sep 2006
    oo well I did not include the other pins on the max7480, because they are not related to the problem ( I guess). The ground is common to the left of the transformer, the pic and the max7480.
    I used the following circuit : http://www.datasheetcatalog.org/data...im/MAX7480.pdf
    page one.
    K
    From the little I know about telephones I think your “On Hook” switch should be across the input capacitor. When the switch is OFF (On Hook) the AC (Ring signal gets through and shows high impedance to the telephone exchange system). When the switch is ON low impedance is shown and the DC circuit is flowing.
    Hope this will help.
    Nick
    Sep 2006
    what I found out is the following:
    ' On Hook: 40 to 50 VDC
    ' Off Hook: 4 to 6 VDC
    ' Ringing: 100 VAC
    I would also like to have the voltage when the other party has pick-up their phone, so I will know when to stop the pic from sending DTMFout.
    I did remove the resistor from the telephone line, and just keeping the capacitor, but no changes. Still cannot dial. I am going to try with an opto coupler instead of the transformer.
    k
    Bombay, India
    Joe has identified the problem precisely. You should not have the capacitor on transformer pin C. That will allow you to 'pick up' the line via the relay and then dial out. No need for the 9 Ohm resistor.
    Sep 2006
    Actually in my second test I installed the relay parallel to the capacitor and remove the series resistor. So when the relay is activate it should bypass the capacitor.
    It still did not work, I will remove the capacitor totally then...
    k
    Here is a tested (not by me) telephone line interface to a microprocessor with part numbers and sources:
    http://www.eettaiwan.com/ARTICLES/20...URCES=DOWNLOAD
    Nick
  1. Dialer detecting end user hookup
    Last Post: - 3rd September 2008, 17:45
  2. Pic Phone Dialer
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 8th August 2007, 11:54
  3. Simon Says Game- Schematic Only
    By T.Jackson in forum Schematics
    Last Post: - 12th May 2007, 09:42
  4. Light Sensor & LCD :: Code & Schematic
    By munim in forum Schematics
    Last Post: - 12th December 2006, 15:51
  5. Schematic for PICPLC16?
    By mugwamp in forum Schematics
    Last Post: - 23rd October 2005, 04:19
