16F887 20Mhz External Clock Problems
Results 1 to 9 of 9
    Does the resonator have 2 legs or 3?
    2 legs (haven't seen many, but haven't looked either) needs caps and grounds.
    3 legs needs a ground...
    Default Resonators at 20 MHz - bad kama IMHO
    I have had very intermittent results with 20 Mhz 3 leg resonators. 4 MHz resonators work every time on every chip I have tried but 20 MHz units have been most disappointing. A few work, most don't. I have tried HS and XT settings but the answer is always the same - intermittent working and bulk frustration.
    Go for the appropriate cut crystal, preferably with the recommended capacitors and I reckon your clock problems will vanish. I have just soldered the crystal into the outer pin positions of the resonator PCB footprint and left the capacitors off and over the last 5 years or more have never had a unit run significantly off frequency.
    HTH
    BrianT
    Hello,
    With all due respect to Brian T. I have no problems whatsoever with the 3 leg resonators, and use 20 mhz almost exclusively. Where I have had problems is from old breadboards. The higher the Frequency, the more affected the circuit is by corrosion, moisture, long lead length induced problems, and just plain funk. If you have to use longish wires to the resonator, then twist them, it seems to help. Make sure your power supply is up to the job and do not forget to tie up the MCLR and tie down any loose inputs. Do not run wires in parallel with the ones going to the resonator, as the added capacitance may load down the OSC.
    Echo'ing Joe's reply...
    Slower resonators (i.e. <8Mhz)...no problems on the messy/quicky boards...
    Faster resonators (i.e. above 10Mhz or so)... Gotta be a clean set up, good solder joints, short runs, clean power, and so on...
    Default Thanks Joe & Skimask
    I almost always prototype my designs piece by piece on solderless breadboards. That is probably why I am getting dodgy results with fast resonators.
    If the solderless version does not work I am most reluctant to build a pcb on the wish that it might with a better layout. I also use a couple of general purpose boards like those from OLIMEX and my own designs but these all have crystals.
    thanks
    BrianT
    Some idea here ???
    4.6 Clock Switching
    The system clock source can be switched between
    external and internal clock sources via software using
    the System Clock Select (SCS) bit of the OSCCON
    register.
    4.6.1 SYSTEM CLOCK SELECT (SCS) BIT
    The System Clock Select (SCS) bit of the OSCCON
    register selects the system clock source that is used for
    the CPU and peripherals.
    • When the SCS bit of the OSCCON register = 0,
    the system clock source is determined by
    configuration of the FOSC<2:0> bits in the
    Configuration Word Register 1 (CONFIG1).
    • When the SCS bit of the OSCCON register = 1,
    the system clock source is chosen by the internal
    oscillator frequency selected by the IRCF<2:0>
    bits of the OSCCON register. After a Reset, the
    SCS bit of the OSCCON register is always
    cleared
  1. Data Out From External Clock
    By Quin in forum Serial
    Last Post: - 25th October 2008, 09:11
  2. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 17:44
  3. Problems with driving external EEPROM M24256
    By Kristjan in forum mel PIC BASIC Pro
    Last Post: - 10th February 2008, 11:34
  4. External clock
    By Firegod in forum mel PIC BASIC Pro
    Last Post: - 17th March 2007, 00:53
  5. How to set external clock source in PBP
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 15:56
