Y A Serial problem
Results 1 to 20 of 20
Threaded View
    jswayze's Avatar
    jswayze Guest
    Default Y A Serial problem
    I hate to do this given the amount of serial questions/answers out there, but I've been spinning my wheels and I could use a little help.
    I'm trying to send serial data from a Visual Basic program on my PC to my PIC. The data is in words, so I split it into high and low bytes.
    For illustrative purposes, I'm currently sending the values directly. In this case, I'm sending a decimal 258 which is b00000001 in the high byte and 00000010 in the low byte.
    My problem is with the PIC end I think. To visualize the actual values of the received data, I have an LED blink the value of the number. When I count the blinks, I get the high byte OK (in this case the LED blinks once) but I end up with double the low byte (4 blinks). Now I realize that this is simply a bit shift left of the low byte, but why is it happening, and why only on the second value?
    Here's the PIC code with the unimportant stuff removed. Oh, and I'm using a 16F628A with internal oscillator.
    @ DEVICE INTRC_OSC, LVP_OFF, WDT_OFF, MCLR_OFF
    define OSC 4
    Baud CON 19697     ' 300 baud, inverted, N,8,1
    LED4 var PORTB.3
    serialData VAR byte
    serialHigh VAR byte
    serialLow VAR byte
    MAIN:
    'Check for setup mode
        SERin2 PROG,Baud,100,START,[wait(253)]  'wait 100ms see a 255
        goto Program_Mode
    START:
        'Do normal program stuff
    goto MAIN
    Program_mode:
        SERin2 PROG,Baud,200,START,[wait(253) ]  'wait for the second of two 253s to start transmission
    'Here is where the values are read in
       SERin2 PROG,Baud,100,START,[serialHigh]
        tempword.Highbyte = serialHigh
        SERin2 PROG,Baud,100,START,[serialLow ]
        tempword.Lowbyte = serialLow
    'Here is where the values are blinked out
    if serialHigh = 0 then gohere
    for i = 1 to serialHigh
    high led4
    pause 20
    low led4
    pause 400
    next i
    gohere:
    for i = 1 to serialLow
    high led4
    pause 20
    low led4
    pause 400
    next i
    Can anyone help? Since it appears to be a bit operation, it seems it must have something to do with stop bits or the way the PIC is receiving the data. I just don't know.
    Oh, and there's been mention of a "binary mode" and "character mode" for serial communications... is there truly such a thing, and could this be part of my problem? Could I be receiving 7 bits instead of 8? I couldn't find any reference to these "modes" in the PBP manual.
    Thanks in advance for your help.
    -Jeff
  1. serial program and sensor problem
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2006, 05:16
  2. Replies: 5
    Last Post: - 20th March 2006, 02:34
  3. Serial Communication Problem
    Last Post: - 23rd February 2006, 03:11
  4. Replies: 8
    Last Post: - 11th November 2004, 21:08
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
