Controling the temperature, humidity of the aviculture with PIC16F877A
Results 1 to 11 of 11
    What you have looks like it will work from the info you gave about the system. So if there is not any surprises.
    On existing machines (systems) that I am going to automate, I get the best human operator I can find to run the machine, then record everything. See what the operator does if a problem comes up and work that into the algorithm.
    ON ERROR 1 GOTO FIX 1
    IF FIX 1 fails THEN ALARM
    You may have the situation where one problem needs fixed with and in dealing with it causes another, so min and max values for the error fixing part.
    I do not know about avicultures, but say the gas levels go up and fresh air is needed, and some how because of the weather this drives up the humidity. Can the humidity be higher than the set point for how ever long it takes to bring the gas levels back into range?
    Just thoughts...
    Iran
    the humidity level is not important, i will define a maximum level but i need a complete and correct algorithm.
    Well that is what I am getting at. I did not know humidity is not much of a problem. So I would maybe have the algorithm wrong. I still think the only ones that can write a correct algorithm for a system is one that completely understands the system. Getting that into code is another story, many here can help with that.
    About the gas sensor. If you can not find one for ammoniac, maybe use an O2 sensor. If I remember correctly, when NH4 goes up O2 goes down. If nothing else is messing with the O2 levels...
    sheepdog's Avatar
    sheepdog Guest
    Quote Originally Posted by amindzo View Post
    Very difficult to provide a correct and precise algorithm as previously stated, to many real world variables, unhatched to hatch parameters to solve. Perhaps an ultrasonic detector to alert of hatchlings so they can be moved to a monitored area to avoid ammoniac poisoning and monitor the ammonia there, (thus not altering the ideal conditions of the hatchery) reducing the problem in this way might be the simplest way.
    Hope it of some help
    sheepdog's Avatar
    sheepdog Guest
    double post
    Thumbs up
    What sensor will you be using? I ask because I have built one of these (without the amoniac gases bit) which not only works (activates relays) but allows the user to define the parameters, such as max/min temp, max/min humidity etc...
    Iran
    i use MQ137 sensor for ammoniac gas
  1. Replies: 10
    Last Post: - 17th February 2012, 07:19
  2. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 18:47
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 18:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 18:20
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 00:14
