12F675 A/D and GPIO sleep interrupt
Results 1 to 11 of 11
    It would help if you hard part values and part descriptions along with voltage levels at
    various nodes in your schematic, but what is connected to the center node entering R1?
    Which state change are you expecting to wake the PIC from sleep? If you're not testing for
    this before entering sleep, you have no idea what level transition causes a wake-up. May
    or may not be important. Just curious.
    Also, if you're just testing for 0-5V why not just use a digital input VS an A/D?
    With 10-bit resolution testing for potvalue >=250 is testing for >=~1.22V. Is the voltage in
    on GPIO.0 and GPIO.5 below the input threshold levels?
    Note: You still need to disable global interrupts. It will jump to location 4 on the 1st wake-
    up so you'll be executing code from somewhere unexpected after the 1st wake-up. If it
    does make it through that somehow global interrupts will be disabled on the 2nd pass, but
    it's still not going to be working like you expect.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2008
    devon
    Bruce,
    Thanks for looking and for some good points.
    The bridge voltage (R1/R2) is either 0V or 4V. I used analog as I may need to be flexible on the voltage values later on.
    The sleep operation does work fine, but I have disabled global interrupt at the start now.
    The problem is that GP4 sometimes goes high of its own accord on switching on. The length of time it stays on varies, after that operation is as I intended. Is this a boot up procedure I have not reckoned with?
    Also, have I assembled the bytes of the 10bit A/D correctly?
    Cheers
    Your A/D part looks fine. If GPIO.4 is going high on power-up, it's most likely due to you
    not initializing the port latches before writing to the tris register. Port latches are unknown
    at power-up so it's a good idea to set the port to whatever you want 1st then write to the
    tris register.
    I.E. GPIO = 0 followed by TRISIO = whatever. Then you know the pins that are outputs will
    be at a certain logic level at POR.
    You have trisio = %00101001, a few other init lines, a pause 1000, then you write to the
    port. You have no idea what value is on the output pins until you write to the port after the
    pause 1000. Which may not be good with your outputs controlling a motor!
    Note: Reading or writing to a port does not clear the interrupt on-change flag. This will just
    end the miss-match condition, which then allows you to manually clear the flag.
    Read the port, then clear the flag, then enter sleep. That may help.
    -Bruce
    tech at rentron.com
    tris register.
    That is really good to know, logic would seem to indicate the opposite which is to say, It would appear that you would set I/O so as to know if ports are outputs or not.<b> YOUR explanation makes good sense.</b>. Another tidbit for your book?
    Thanks for that BRUCE,
    JS
    Jul 2008
    devon
    Smile
    Thanks Bruce, thanks Joe.S.
    The project is now working. I hope this is useful to others too.
    It's a good forum.
    Cheers
    macinug
  1. Interrupt question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 21:12
  2. Is it a correct way to deal with an interrupt?
    Last Post: - 15th November 2009, 23:44
  3. rfPIC Serin problem
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 18:52
  4. Scale 8bit ADC RGB LED voltmeter
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2008, 04:37
  5. 12f675 programming question
    By puggy in forum General
    Last Post: - 1st December 2004, 00:34
