how can imake interrupt by TMR0
Results 1 to 5 of 5
    Aug 2008
    Default how can imake interrupt by TMR0
    hello
    am using picbaisc pro i want make interrupt every 50ms and goto spacial sup routine
    iwant help plzzzzzzzzz
    Please (plzzzzzzzz) look at Darrel's Instant Interrupt routines. It will let you do what you need.
    Aug 2008
    '* Name : UNTITLED.BAS *
    '* Author : [eng . Mohammad Alamin Ali] *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 8/23/2008 *
    '* Version : 1.0 *
    '* Notes : ero servo driver *
    define osc 12
    include "modedefs.bas"
    value var byte
    angle var byte
    d var byte [16]
    INTCON = %00100000
    option_reg = %11100100
    TMR0 = 100
    on interrupt goto submain
    INTCON = %10100000
    serin2 portc.1 , 84 , [WAIT($A6 ,$41), str d\9 ]
    if d[0] = $C6 then
    high portc.0
    disable
    submain:
    high portc.4
    gosub servo1
    gosub servo2
    gosub servo3
    gosub servo4
    gosub servo5
    gosub servo6
    gosub servo7
    gosub servo8
    TMR0 = 100
    INTCON.2 = 0
    resume
    enable
    servo1:
    servo2:
    servo3:
    etc
    this code spouse to jump to submain when timer over flaw but it never goto sub routine
    idon't know why
    can you help me (please )
    regard
    Which PIC is this?
    /H.
    Aug 2008
    am using 16f877a but guess what i found the problem
    the problem is going to sub routine from sub routine
    but other wise it worked probably
    thanx man for your attention
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  4. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 01:07
