MPLAB and PBP ...
Results 1 to 5 of 5
    Unhappy MPLAB and PBP ...
    I had been working for years with MPLAB and PBP ... no soucy.
    BUT Yesterday, my computer hung on while I was trying some USB program ... and MPLAB was open.
    RESULT:
    All the compilers ( including MPASM ! , PbP .... etc, etc ) have disappeared from the Toolsuite selection window ... BUT their locations are still here in the Location window.
    So, no way to create a new project ... but old ones still compile fine !!!
    Verified the PATH ... ( could someone showme a Win XP Home example ??? just to compare if something had been lost )
    Made a system restore ... nothing
    Made a damaged files search and repare ... nothing
    Reinstalled MPLAB, C18, PbP ( and its DLL's) ... NO CHANGE.
    A file has surely been corrupted ... but which ???
    Thanks for the ideas ... by the time, I'll use MCS !!!
    Jan 2006
    Istanbul
    Are you saying that you had some files there but now you can not see them?
    If this is the case, then you can recover the files that had been lost.
    There is this program named "Active File Recovery".
    You can even recover a formatted HDD ; if not much written on it.
    So, be alone while running the program cause if you find a picture with someone at somewhere that for sure deleted years ago, some unpleasant moments may occur!
    Aug 2005
    down south
    xp home
    %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\Sy stem32\Wbem;C:\Program Files\Common Files\Ulead Systems\MPEG;C:\PBP;C:\Program Files\Microchip\MPASM Suite
    and I'm sure you have been here
    http://melabs.com/support/mplab.htm
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    are the paths missing from there?
    If so, then go to the MPLAB help /MPASM/MPLAB IDE Setup
    and it tells all of the paths there.
    I know, you been there done that
    Smile Solution !
    Hi, Everyone
    Microchip knows the problem ... but do not have a fix !!!
    I turned back to V8.10 AND reloaded Hi-TECH C compiler 9.60 PL 1
    ( µChip seems to think the problem is due to the new HiTech PRO C compiler ... )
    Now everything is back and fine ...
    I will try to re-Upgrade to MPLAB 8.14 Tomorrow ...
    Keep on the line for the results
    Thanks for the ones who helped ... verifying everything is not lost time !!!
  1. MPLab and Picstart plus with PBP...
    By gregcan in forum mel PIC BASIC Pro
    Last Post: - 8th October 2009, 15:36
  2. PBP and MPLab IDE
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 29th May 2008, 15:09
  3. pbp --> mplab broken again
    By kenif in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:57
  4. PBP in MPLAB
    By zagisrule! in forum mel PIC BASIC Pro
    Last Post: - 29th December 2005, 02:58
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
