Oh, that is cheap! I ordered the components and circuit board separately and it cost about 25 euros. Im not really sure what you mean by "power the PIC from a 5 volt supply while programming" but this has to do something with not using LVP?
I tried the code, it uploaded to the chip and program said it was successfull, like before. But that damn LED didnt ligth up and no sign of life there. Now i tried to read the memory from chip with programmer, it looks like this:
:1000000000000000FF3FFF3FFF3F8F3FFF3FFF3FEC
:10001000280EF23F060883169F00831206089F00F1
:100020000608840087018801890106088600060801
:1000300085000608650006088316870083120608F7
:1000400083168800FF3FFF3FFF3FFF3FFF3FFF3F1B
:10005000FF3F0800FF3FFF3FFF3FFF3FFF3FFF3FE6
:10006000FF3F8312FF3FFF3FFF3FFF3FFF3FFF3F49
:10007000FF3F0610FF3FFF3FFF3FFF3FFF3FFF3FB8
:10008000FF3F2C28FF3FFF3F4028FF3FFF3FFF3F40
:10009000FF3FFF3FFF3FFF3FFF3FFF3FFF3FFF3F70
:1000A000FF3F0A12FF3FFF3FFF3FFF3FFF3FFF3F82
:1000B000FF3F0A12FF3FFF3FFF3FFF3FFF3FFF3F72
:1000C000FF3F2108FF3FFF3FFF3FFF3FFF3FFF3F55
:1000D000FF3F0800000000000000000000000000DA
:1000E0000000000000000000000000000000000010
:1000F0000000000000000000000000000000000000
:1001000000000000000000000000000000000000EF
:1001100000000000000000000000000000000000DF
:1001200000000000000000000000000000000000CF
Theres a quite a few 3FF:s that seems suspicious. Here is the viberer.hex:
:100000002828A301A200FF30A207031CA307031C9A
:1000100023280330A100DF300F200328A101E83E90
:10002000A000A109FC30031C1828A00703181528FC
:10003000A0076400A10F152820181E28A01C222844
:1000400000002228080083130313831264000800B1
:100050008601831686018312061483160610831206
:100060000330A300E8308A01022006108316061030
:1000700083120330A300E8308A0102208A012C2871
:0600800063008A01402824
:02400E00F23F7F
:00000001FF
I assume that the codes are not supposed to be clone of each other, but can you say from this if it is corrupted?
Another assume i made is that if i upload a longer program to the chip and then a shorter one, part of the longer program still remains in the memory but this is not issue since the new shorter code has its end coded or a infinite loop at the end. Is this rigth?
I assumed this becouse there are no option to empty the memory in the program. If i want to "clear the memory" is it ok to program this kind of .hex to the chip:
:1000000000000000000000000000000000000000F0
:1000100000000000000000000000000000000000E0
:1000200000000000000000000000000000000000D0
:1000300000000000000000000000000000000000C0
:1000400000000000000000000000000000000000B0
:1000500000000000000000000000000000000000A0
:100060000000000000000000000000000000000090
:100070000000000000000000000000000000000080
:100080000000000000000000000000000000000070
:100090000000000000000000000000000000000060
:1000A0000000000000000000000000000000000050
:1000B0000000000000000000000000000000000040
:1000C0000000000000000000000000000000000030
:1000D0000000000000000000000000000000000020
:1001300000000000000000000000000000000000BF
:1001400000000000000000000000000000000000AF
:10015000000000000000000000000000000000009F
:10016000000000000000000000000000000000008F
:10017000000000000000000000000000000000007F
:10018000000000000000000000000000000000006F
:10019000000000000000000000000000000000005F
:1001A000000000000000000000000000000000004F
................ and so?
