Wireless Comunication Dilemma
Results 1 to 10 of 10
    Dec 2007
    Default Wireless Comunication Dilemma
    Hello Again,
    I have another problem with wireless communication, this time with IR.
    I am trying to setup stable IR communication between to PIC's but I cannot get it to work.
    For the transmitter i am using the 16F628 because of its Hardware PWM and for the receiver i am using the 12F629 because i have a heap of them.
    Below is the code for the PIC's, can anyone see anything wrong?
    Reciever Code<code>
    INCLUDE "modedefs.bas"
    @ DEVICE PIC12f629, XT_OSC
    @ DEVICE PIC12f629, WDT_OFF
    @ DEVICE PIC12f629, PWRT_ON
    @ DEVICE PIC12f629, MCLR_OFF
    @ DEVICE PIC12f629, BOD_ON
    @ DEVICE PIC12f629, CPD_OFF
    Define OSC 4
    CMCON = 7
    RXPIN Var GPIO.1 'Input PIN
    TXPIN VAR GPIO.2 'Output PIN
    VALID VAR byte 'Valid Code
    UTYPE VAR BYTE 'Unit Type
    UID VAR BYTE 'Unit Identefier
    VALID = 0
    utype = 0
    uid = 0
    LOW 0
    rx:
    serin rxpin,n1200,[$66],VALID,UTYPE,UID
    if VALID = 22 then hit
    goto rx
    hit:
    high 0
    pause 250
    low 0
    VALID = 0
    goto rx
    </code>
    Transmitter Code<code>
    @ DEVICE PIC16f628, XT_OSC
    @ DEVICE PIC16f628, LVP_OFF
    @ DEVICE PIC16f628, WDT_OFF
    @ DEVICE PIC16f628, MCLR_OFF
    DEFINE OSC 4 ' We're using a 4MHz oscillator
    TXPIN Var PortB.1 ' Output PIN
    VALID CON 22 ' Valid Code
    UTYPE CON 27 ' Unit Type
    UID con 2550 ' Unit Identefier
    ' Initialize hardware PWM - IRLED 38KHz drive
    PORTB = %00000000 ' PortB = 0 : IRLED On PortB.1 Off
    TRISB = %00000000 ' PortB = all outputs
    PR2 = 25 ' Set PWM for approximately 38KHz
    CCPR1L = 13 ' Set PWM Duty-Cycle to 50%
    CCP1CON = %00001100 ' Mode select = PWM
    T2CON = %00000100 ' Timer2 ON + 1:1 prescale
    IR_TX:
    serout txpin,n1200,[$66,VALID,UTYPE,UID]
    PAUSE 1000 ' 1sec delay
    GOTO IR_TX
    </code>
    Thank Again,
    Jeremy
    Bombay, India
    Quote Originally Posted by jhorsburgh View Post
    Hello Again,
    rx:
    goto rx
    hit:
    </code>
    Jeremy
    After a cursory glance at your code, I think the statement in RX should change to
    rx:
            serin rxpin,n1200,[WAIT($66),VALID,UTYPE,UID]
    Wait for $66 and then read the rest.
    Dec 2007
    Hey Jerson,
    I tried changing the the code but for some reason when i try to compile the code, the following error occurrs. <code>ERROR Line 25: Bad expression. (RX.pbp)</code>
    <code>rx:
    serin rxpin,n1200,[WAIT($66),VALID,UTYPE,UID] 'Line 25
    goto rx</code>
    Is it the software i am using?
    MicroCode Studio - PBP Compiler
    The previous code works using RF modules but not for IR.
    Jeremy
    Double check the syntax for SERIN and the wait modifier.
    Other than that, are you sure the hardware is working correctly, everything is matched?
    If you have not seen this it may help. The receiver code is for a BS2 though.
    http://www.rentron.com/Infrared_Communication.htm
    See this example http://www.rentron.com/Micro-Bot/IR_Serial.htm
    SERIN does not require the WAIT modifier. Just enclose the qualifier in square
    brackets. SERIN2 can be used with the WAIT modifier followed by the qualifier
    in square brackets.
    -Bruce
    tech at rentron.com
    Dec 2007
    Thanks Guys,
    I have been looking around at different posts and the internet and i can't find a solution, they all say what i am doing is correct but it does not work. I have attached a copy of the wiring for you guys to look at. The only other thing i can think of in the Baud Rate and the way its driven. Should N1200 work? or should i drive it TRUE?
    Thanks Again,
    Jeremy
    Your drawing will not display. Try uploading again.
    Dec 2007
    does this attachment work better? PS. i forgot to put the external oscillator on the the drawing, but its connected.
    Jeremy
    All I get is this
    "The image “http://www.picbasic.co.uk/forum/atta...;d=1220015090” cannot be displayed, because it contains errors."
    Once you have the basic setup working, I suggest you drive the LED from just the PWM pin (ground the cathode), by controlling the output of the pin as per your data requirement; you will find a significant improvement in range.
    Anand
  1. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 06:20
  2. Wireless Tachometer - Design Help
    By DanPBP in forum Off Topic
    Last Post: - 3rd May 2009, 10:06
  3. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 13:40
  4. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  5. Wireless communication gear.
    By toalan in forum Off Topic
    Last Post: - 17th March 2005, 17:33
