12F629 Wakes only once
Results 1 to 15 of 15
    Default 12F629 Wakes only once
    I thought I understood this interrupt thing, but NO! The following program will wake from SLEEP with GPIO.2 going high the first time, but not with subsequent highs. What am I doing wrong? (The last three lines never get executed.) Thank you for any help.
    CMCON = 7
    TRISIO = %001100
    OPTION_REG = %01000000
    GPIO = 0
    T1CON = 0
    @ DEVICE MCLR_OFF, INTRC_OSC_NOCLKOUT, WDT_OFF, BOD_OFF, PWRT_ON, PROTECT_ON
    'GPIO.0 =
    'GPIO.1 = LED HIGH OUT
    'GPIO.2 = SWITCH HIGH INPUT
    'GPIO.3 = MCLR TIED HIGH
    'GPIO.4 =
    'GPIO.5 =
    HIGH GPIO.1
    PAUSE 1000
    LOW GPIO.1
    INTCON.1 = 0
    INTCON.4 = 1
    FLAGS = 0
    @ SLEEP
    @ NOP
    INTCON.1 = 0
    HIGH GPIO.1
    PAUSE 100
    LOW GPIO.1
    INTCON.1 = 0
    INTCON.4 = 1
    FLAGS = 0
    @ SLEEP
    @ NOP
    HIGH GPIO.1
    PAUSE 1000
    USA - Arizona
    I believe you may have a mismatch condition on the ports.
    Try changing the following:
    INTCON.1 = 0
    HIGH GPIO.1
    PAUSE 100
    LOW GPIO.1
    to:
    temp = GPIO.2'read to dummy variable to clear mismatch condition of port (see s3.2.2 of datasheet)
    INTCON.1 = 0
    HIGH GPIO.1
    PAUSE 100
    LOW GPIO.1
    Hi Languer- Thanks for trying, but no cigar! Adding the line you suggested resulted in a syntax error, so I added INTCON.0 = 0 instead (To clear GPIF). I get the same result. Strange.
    Aug 2008
    Please put a pull down resistor 10K to GND from GPIO.2
    I currently have a 3k resistor there.
    Place GOTO Main after your last PAUSE 1000. You should see a quick 100mS pulse on the
    LED after the 1st wake-up, and a 2 second LED on time after the 2nd wake-up.
    Using the internal oscillator you might also want to include DEFINE OSCCAL_1K 1 to make
    sure it's calibrated.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. 12F629 LDR - Light Dependant Resistor
    By Dennis in forum Schematics
    Last Post: - 18th February 2010, 23:33
  2. Basic help for 12F629
    By Gene Choin in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 05:06
  3. sleep on 12f629
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:08
  4. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 00:34
  5. 12F629 I2C problems
    By AIW128ProGuy in forum mel PIC BASIC Pro
    Last Post: - 12th November 2004, 00:41
