HPWM on second half
Results 1 to 23 of 23
    Swordfish is awesome, but isn't the entire library in Swordfish BASIC?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2007
    Yes, the library is in SF BASIC. Makes it real easy to extend and/or modify to suit.
    I totally agree, but it's not much use unless you own the compiler. PBP libraries are pure
    assembler. You can modify them as needed, learn asembler by understanding them, and
    cut/paste sections into your own assembler programs.
    And of course PBP supports the whole PIC series unlike Swordfish or C18, which are only
    for 18F parts, and very limiting.
    Most C compilers have open libraries as well, but it's not anything like the PBP library where
    you have the assembly language equivalent of each command. Huge difference.
    -Bruce
    tech at rentron.com
    Sep 2006
    I wrote a small program , mostly copied it from one of the post here. it works but the frequency it gives me is 2,2kHz when I program 500hz, I am doing a HPWM: using picF88.
    can someone help me?
    INCLUDE "modedefs.bas"
    @ DEVICE PIC16F88 , HS_OSC , WDT_OFF , PWRT_ON , BOD_ON , LVP_OFF , PROTECT_OFF, CCPMX_OFF
    'HS 20mhz, watchdog off, powerup timer on, mclr external, brown out detect on, low volt program off , code protect off
    DEFINE OSC 20 'use external 20mhz crystal
    PAUSE 100 ' start-up delay
    TRISB=0
    DEFINE CCP1_REG PORTB
    DEFINE CCP1_BIT 3
    HPWM 1,127,500
    HERE: GOTO HERE
    I think you are hitting the bottom of the frequency range for that oscillator speed, try changing to 4Mhz x-tal.
    EDIT: Just checked the manual....with a 20Mhz clock the lowest HPWM frequency is stated as 1221Hz for the 14bit core PICs - isn't the F88 a 14bit PIC? Don't know why you'd get 2.2kHz.....
    Sep 2006
    yes that is it,
    thanks
    Sep 2006
    Default hum
    Rmteo..
    you mentionned earlier
    "A better solution would be to use a PIC with an ECCP (Enhanced Compare Capture) module. Many of the newer PIC's have this feature. Set it up to operate in Half-Bridge mode and you will get a PWM signal on the P1A pin and a complementary signal on P1B. Plus you can control the programmable dead-band delay which is used to prevent shoot-through current in half-bridge devices."
    I understand what a half bridge is, but I am bit confused about configuring the pic in half bridge mode.. what do you mean by that?
    So far I added an inverter at my HPWM output, I would still like to get two ports, I ordered chips which includes the eccp mode.
    K
  1. Bit Angle Modulation (BAM) in a PIC
    By Bronx68 in forum mel PIC BASIC Pro
    Last Post: - 24th February 2015, 13:41
  2. 18F4620 HPWM Half Bridge Mod problem
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 12:55
  3. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 11:18
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
