How to use GPIO meant for OSC
Results 1 to 3 of 3
    Aug 2008
    Default How to use GPIO meant for OSC
    I'm not sure how to use PicBasic to configure PIC12F629 so that GP3,4,5 can be used as GPIO. Any idea without using assembly? I want to use internal 20MHz oscillation.
    Set the config to
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    Then you can use the internal 4 MHz osc and GP3 can be used for an input.
    Then turn off the ADC
    Aug 2008
    Problem solved. Need to use the following code if not using MPASM assembler in PBP:
    asm
    device pic12F629, MCLR_OFF,INTRC_OSC_NOCLKOUT, wdt_off, pwrt_on,protect_off
    endasm
  1. Gpio ? Trisio ?
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 15th October 2008, 15:38
  2. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 15:39
  3. 12f629 Gpio
    By alfredo canales in forum mel PIC BASIC Pro
    Last Post: - 14th May 2008, 13:53
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  5. 12c508 Gpio
    By oki_one in forum mel PIC BASIC Pro
    Last Post: - 26th August 2003, 08:51
