send data from pc(Visual Basic) to pic16f877a through serial port(DB9)
Results 1 to 10 of 10
    Or might be because PIN 16 is not a valid pin , funny I have never used PINs always used PortA, PortB etc . . less confusing I guess . . . anyway only 0-15 are valid: SEC. 4.11. PINS
    Aug 2008
    so what is your suggestion joe s.????
    HenrikOlsson and Joe are saying change your code from
    Serin 16,16780,[WAIT(255),PinNumber,PinState]
    to
    SERIN2 PORT?.?,16780,[WAIT(255),PinNumber,PinState]
    Seems to work much better using for example:
    PORTC.3
    instead of
    PIN?
    Mar 2005
    Iowa, USA
    texas5 -
    Please note the information on Bruce's website prior to the code for this example:
    Quote Originally Posted by http://www.rentron.com/sending_data.htm
    The Microcontroller Part
    For simplicity I am going to use a Basic Stamp II to receive the data and act accordingly to the data. You will need to hook up the Basic Stamp II just like you are going to program it and use the programming port (pin 16) for communications. Program the Basic Stamp II with the following code...
    That's probably where there is some confusion.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Aug 2008
    emmmmm....thanx for the information....
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Replies: 2
    Last Post: - 24th August 2008, 21:03
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
