send data from pc(Visual Basic) to pic16f877a through serial port(DB9)
Results 1 to 10 of 10
    Aug 2008
    Default send data from pc(Visual Basic) to pic16f877a through serial port(DB9)
    hi.i want to send data from pc(Visual Basic) to pic16f877a through serial port(DB9).all the hardware have been setup(i'm using max232).can someone help me for the coding part(both code for VB and pic).just a simple code(LED blinking) for testing my pic circuit.
    Have a look here
    Aug 2008
    thanx man...
    Aug 2008
    here's the code for micro controller:
    PinNumber var byte
    PinState var byte
    ' Use the programming port to receive
    ' data at 2400 baud
    ' Wait for the synch byte (255) and then
    ' get the PinNumber and PinState
    Serin 16,16780,[WAIT(255),PinNumber,PinState]
    ' If PinState=0 Then go to GoLow
    ' otherwise go to GoHigh
    Branch PinState,[GoLow,GoHigh]
    Goto Main
    ' Set The pin low
    GoLow:
    LOW PinNumber
    Goto Main
    ' Set the pin high
    GoHigh:
    HIGH PinNumber
    Goto Main
    i have problem when compile it....the 'Serin 16,16780,[WAIT(255),PinNumber,PinState]' appear as bad expression...why is it???
    That's probably because WAIT isn't supported by the SERIN command, you'd need to change that to SERIN2 i think.
    Or might be because PIN 16 is not a valid pin , funny I have never used PINs always used PortA, PortB etc . . less confusing I guess . . . anyway only 0-15 are valid: SEC. 4.11. PINS
    Aug 2008
    so what is your suggestion joe s.????
    HenrikOlsson and Joe are saying change your code from
    to
    SERIN2 PORT?.?,16780,[WAIT(255),PinNumber,PinState]
    Seems to work much better using for example:
    PORTC.3
    instead of
    PIN?
    Mar 2005
    Iowa, USA
    texas5 -
    Please note the information on Bruce's website prior to the code for this example:
    Quote Originally Posted by http://www.rentron.com/sending_data.htm
    The Microcontroller Part
    For simplicity I am going to use a Basic Stamp II to receive the data and act accordingly to the data. You will need to hook up the Basic Stamp II just like you are going to program it and use the programming port (pin 16) for communications. Program the Basic Stamp II with the following code...
    That's probably where there is some confusion.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Aug 2008
    emmmmm....thanx for the information....
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Replies: 2
    Last Post: - 24th August 2008, 21:03
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
