LCD / PC question
Results 1 to 11 of 11
    Perth, Australia
    hserout[reading] will not display the value of "reading", it will send "reading" as if it was an ascii character. so for example, if reading=37 you will see the character % on your terminal.
    You need to use hserout[DEC reading] for it to display the decimal representation of the value of reading.
    *edit* also, check to make sure the serial out is working. try hserout["Test"] and see if u get Test on your terminal.
    May 2007
    Area 71
    I changed my code to :
    LCDOUT $FE, 1
    LCDOUT $FE, $C0, "test"
    hserout ["test" ]
    LCD displays "test" , nO problem
    Terminal program displays:"
    ÈKÛ¼ìÿ ( String )
    C8 4B DB BC EC FF (Hex)
    Perth, Australia
    Its a problem with your serial baud settings for your pic.
    Change the SPBRG value to 64 like this:
    DEFINE HSER_SPBRG 64
    You could probably even remove that line altogether.
    May 2007
    Area 71
    thanks Kamikaze
    After few hours trying any possible setup, I solved the problem
    The problem is with HSPLL config.
    If I change the config to:
    _FOSC_HS_1H
    define osc 10, it works
    but if I change the config to :
    _FOSC_HSPLL_HS_1H
    define osc 40, it did not work as expected
    HSPLL suppose to multiply the frequency, and if I define osc to 40 ( 4x ) it should be working right out of the box , right ? Or did I forget something ?
    Could anyone share information about this ?
    Perth, Australia
    The PLL expects an input frequency that is a multiple of 4, which your 10 Mhz clock is not.
    For this PIC I usually use a 4Mhz crystal with _PLLDIV_1_1L, _CPUDIV_OSC1_PLL2_1L, and _USBDIV_2_1L which results in a 48Mhz clock for the processor.
    Have a look at the table in the data sheet on pages 29 and 30.
    edit: also have a look at the figure on page 24 - it shows that the PLL must have a 4Mhz input.
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
