LCD / PC question
Results 1 to 11 of 11
    So try:
    adcin 0,reading
    lcdout $Fe,1,"   value:    "
    LCDOUT $FE, $C0, dec reading
    pause 50
    hserout [DEC reading,10] ' DECIMAL VALUE OF READING WITH LINEFEED
    pause 50
    PP 80:81 ver 2.47
    PP 82:83 ver 2.5
    Note: I only looked at Hserout code. . .
    May 2007
    Area 71
    Thank you for yor comments,
    Joe: adding DEC statement caused the value in Terminal program incorrect , it spits more character
    This is my code, please check if there is something wrong with fuses or defines
    I use 18F2550, 10mhz xtal with hs pll ( 40mhz)
            __CONFIG    _CONFIG1L, _PLLDIV_10_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_1_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _VREGEN_OFF_2L
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_ON_3H  & _CCP2MX_ON_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L  & _DEBUG_OFF_4L
    define OSC 40
    DEFINE LCD_DREG PORTB     ' LCD data port
    DEFINE LCD_DBIT 0         ' LCD data starting bit
    DEFINE LCD_RSREG PORTB    ' LCD register select port
    DEFINE LCD_RSBIT 4        ' LCD register select bit
    DEFINE LCD_EREG PORTB     ' LCD enable port
    DEFINE LCD_EBIT 5         ' LCD enable bit
    DEFINE LCD_BITS 4         ' LCD data bus size
    DEFINE LCD_LINES 2        ' Number lines on LCD
    DEFINE LCD_COMMANDUS 1500 ' Command delay time in us
    DEFINE LCD_DATAUS 44      ' Data delay time in us
    DEFINE ADC_BITS 8               ' ADC resolution 8 bit
    DEFINE ADC_CLOCK 3              '
    DEFINE ADC_SAMPLEUS 50
    define HSER_RCSTA 90H
    DEFINE HSER_TXSTA 20H
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    DEFINE HSER_CLROERR 1
    reading var byte
    clear
    porta = 0
    portb = 0
    portc = 0
    TRISA = %00000001               ' Set PORTA to all input
    TRISB = %00000000               ' Set PORTB to all output
    TRISC = %00000000               ' Set PORTC.7 as input, other RC as output
    ADCON1 = %00001110
    LCDOUT $FE, 1
    adcin 0,reading
    lcdout $Fe,1,"   Value    "
    pause 50
    hserout [reading ]
    pause 50
    May 2007
    Area 71
    I just modified the program as follow:
    LCDOUT $FE, 1
    for reading = 1 to 10
    hserout [reading ]
    next reading
    LCD shows 1 to 10 sequence correctly, but the terminal program shows:
    3
    254
    4
    254
    7
    254
    8
    254
    11
    254
    12
    254
    15
    254
    48
    254
    51
    254
    52
    254
    What is wrong ?
    Perth, Australia
    hserout[reading] will not display the value of "reading", it will send "reading" as if it was an ascii character. so for example, if reading=37 you will see the character % on your terminal.
    You need to use hserout[DEC reading] for it to display the decimal representation of the value of reading.
    *edit* also, check to make sure the serial out is working. try hserout["Test"] and see if u get Test on your terminal.
    May 2007
    Area 71
    I changed my code to :
    LCDOUT $FE, 1
    LCDOUT $FE, $C0, "test"
    hserout ["test" ]
    LCD displays "test" , nO problem
    Terminal program displays:"
    ÈKÛ¼ìÿ ( String )
    C8 4B DB BC EC FF (Hex)
    Perth, Australia
    Its a problem with your serial baud settings for your pic.
    Change the SPBRG value to 64 like this:
    DEFINE HSER_SPBRG 64
    You could probably even remove that line altogether.
    May 2007
    Area 71
    thanks Kamikaze
    After few hours trying any possible setup, I solved the problem
    The problem is with HSPLL config.
    If I change the config to:
    _FOSC_HS_1H
    define osc 10, it works
    but if I change the config to :
    _FOSC_HSPLL_HS_1H
    define osc 40, it did not work as expected
    HSPLL suppose to multiply the frequency, and if I define osc to 40 ( 4x ) it should be working right out of the box , right ? Or did I forget something ?
    Could anyone share information about this ?
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
