LCD / PC question
Results 1 to 11 of 11
    May 2007
    Area 71
    Exclamation LCD / PC question
    I tried to connect my PIC to PC
    LCD shows value exactly as the reading ( 0 to 255 ), but the terminal program shows a 2 bytes combination ( 0 / 0 to 255 / 255 )
    For example : at reading 0, LCD shows 0 and terminal shows 0 0,
    at reading 255, LCD shows 255 and terminal shows 255 255,
    How to make both display the same reading - I want PC terminal displays the same reading as LCD (0 to 255 )? Thank you
    adcin 0,reading
    lcdout $Fe,1,"   value:    "
    LCDOUT $FE, $C0, dec reading
    pause 50
    hserout [reading]
    pause 50
    Hi luminas,
    is the variable "reading" a word, or byte variable ?
    Perth, Australia
    that "main" loop will continue looping, but each time the LCD will be cleared and the value re-written, however, the pc will just keep receiving a value each time, so you will get a whole heap of values spit out in your terminal.
    So try:
    adcin 0,reading
    pause 50
    hserout [DEC reading,10] ' DECIMAL VALUE OF READING WITH LINEFEED
    pause 50
    PP 80:81 ver 2.47
    PP 82:83 ver 2.5
    Note: I only looked at Hserout code. . .
    May 2007
    Area 71
    Thank you for yor comments,
    Joe: adding DEC statement caused the value in Terminal program incorrect , it spits more character
    This is my code, please check if there is something wrong with fuses or defines
    I use 18F2550, 10mhz xtal with hs pll ( 40mhz)
            __CONFIG    _CONFIG1L, _PLLDIV_10_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_1_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _VREGEN_OFF_2L
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_ON_3H  & _CCP2MX_ON_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L  & _DEBUG_OFF_4L
    define OSC 40
    DEFINE LCD_DREG PORTB     ' LCD data port
    DEFINE LCD_DBIT 0         ' LCD data starting bit
    DEFINE LCD_RSREG PORTB    ' LCD register select port
    DEFINE LCD_RSBIT 4        ' LCD register select bit
    DEFINE LCD_EREG PORTB     ' LCD enable port
    DEFINE LCD_EBIT 5         ' LCD enable bit
    DEFINE LCD_BITS 4         ' LCD data bus size
    DEFINE LCD_LINES 2        ' Number lines on LCD
    DEFINE LCD_COMMANDUS 1500 ' Command delay time in us
    DEFINE LCD_DATAUS 44      ' Data delay time in us
    DEFINE ADC_BITS 8               ' ADC resolution 8 bit
    DEFINE ADC_CLOCK 3              '
    DEFINE ADC_SAMPLEUS 50
    define HSER_RCSTA 90H
    DEFINE HSER_TXSTA 20H
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    DEFINE HSER_CLROERR 1
    reading var byte
    clear
    porta = 0
    portb = 0
    portc = 0
    TRISA = %00000001               ' Set PORTA to all input
    TRISB = %00000000               ' Set PORTB to all output
    TRISC = %00000000               ' Set PORTC.7 as input, other RC as output
    ADCON1 = %00001110
    LCDOUT $FE, 1
    adcin 0,reading
    lcdout $Fe,1,"   Value    "
    pause 50
    hserout [reading ]
    pause 50
    May 2007
    Area 71
    I just modified the program as follow:
    LCDOUT $FE, 1
    for reading = 1 to 10
    hserout [reading ]
    next reading
    LCD shows 1 to 10 sequence correctly, but the terminal program shows:
    3
    254
    4
    254
    7
    254
    8
    254
    11
    254
    12
    254
    15
    254
    48
    254
    51
    254
    52
    254
    What is wrong ?
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
