16f628a wont wake up
Results 1 to 5 of 5
    Feb 2005
    Default 16f628a wont wake up
    Right,
    Have a 16f628a.
    @ DEVICE pic16F628A, INTOSC_OSC_NOCLKOUT
    @ DEVICE pic16F628A, WDT_OFF
    @ DEVICE pic16F628A, PWRT_ON
    @ DEVICE pic16F628A, MCLR_OFF
    @ DEVICE pic16F628A, BOD_OFF
    @ DEVICE pic16F628A, LVP_OFF
    @ DEVICE pic16F628A, CPD_OFF
    @ DEVICE pic16F628A, PROTECT_OFF
    Use the memreset pin as input switch, start, tied high via resistor, cap across switch.
    At the end of the program
    @ sleep
    goto beginning of program
    Now....
    It goes to sleep, no problem, but when i power down and reapply power,
    hence using pwrttimer reset option, it stays ASLEEP !!!
    help, please ?
    can post complete code, but over 700 lines.
    Pete
    Wink
    Quote Originally Posted by Peter1960 View Post
    help, please ?
    But, may be you could post the " beginning of program " AND the " Sleep config "( with some lines before the @ sleep command ) sections.
    THE good question :
    Some interrupts used ??? ...
    Jan 2006
    Istanbul
    @ DEVICE pic16F628A, WDT_ON
    __________________________-
    Wink You sure ???
    Quote Originally Posted by sayzer View Post
    Hi, Sayzer
    That way you are sure the Pic will not sleep too long a time ...
    With BOD_OFF this PIC can run with a supply of around 3V. If you cycle power quickly, and
    have enough capacitance on the power supply rail to hold Vdd >=3V during cycle time, it
    may not allow time for the PIC to reset, so it would never exit sleep.
    You could try BOD_ON or just allow time for a full reset when cycling power off/on.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. 16F181: can't wake up from sleep
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 05:33
  2. MPLAB ICD ver 1 & 16F628A
    Last Post: - 26th February 2005, 01:44
  3. 16F628A sleep current
    By David Marks in forum mel PIC BASIC Pro
    Last Post: - 9th February 2005, 16:12
  4. new user with problem using PGP Pro, Lab-X3 with 16F628A
    By equipoise in forum mel PIC BASIC Pro
    Last Post: - 28th July 2004, 08:42
  5. HSEROUT and 16F628A
    By fredblah in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 01:07
