Config problem PIC16F886
Results 1 to 40 of 56
    Quote Originally Posted by Bosse View Post
    Now it is running nice - still a warning from PicKit2 - Configuration 23EC 0700
    I think, but I'm not sure...
    The datasheet says that the upper 2 bits of the CONFIG1 register should read as 1's (even though they're not used), and the same thing for most of CONFIG2.
    This leads me to believe that your config word should be $E3ECFFFF when read back off the chip.
    Have you got the latest versions of MPLAB, PICKIT2 firmware and software loaded up?
    Sep 2006
    Yes, have MPLAB Ver. 8.00.00.00 and updated PicKit2
    Shall read bak and see
    MPLAB is up to 8.14.
    PicKit2...check the website for the latest.
    Sep 2006
    Hi again skimask,
    This is my configuration now, will move it to the INC file when there is no warnings.
    @ __CONFIG _CONFIG1, _INTOSCIO & _WDT_ON & _PWRTE_ON &_MCLRE_ON & _LVP_OFF & _CPD_OFF & _FCMEN_OFF & _IESO_OFF
    Define OSC 8 ' Set Xtal Frequency
    OSCCON = %01110001 ' Internal 8 mhz Osc
    ANSEL = 0 ' All Digital
    ANSELH = 0
    CM1CON0 = 0 ' Think ? don't need
    CM2CON0 = 0 ' Think ? don't need
    ADCON0 = 0
    ADCON1 = $0F ' Think ? don't need
    Have to try change bit by bit until no warnings from PicKit2
    Anything below this line isn't going to have an effect on your CONFIG fuses.
    They are 2 separate entities...
    And when I said read back, I meant the actual config word data as read back using the PICKIT2, not the data you are trying to push out to the PIC using the programmer.
    EDIT: Just checked your CONFIG against the '886/887 datasheet. When reading back the PIC after programming the config word, you should readback $E3ECFFFF, if it's actually being programmed to those values.
    Sep 2006
    Have Updated MPLAB to 8.14 and PicKit to 2.52
    Reading back 23EC 3FFF
    If I had an '886, I'd try it to see what I get.
    Oh...wait...I've got the demo board with an '887 on it.
    When I get a chance, I'll see what it reads...
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
