Config problem PIC16F886
Results 1 to 40 of 56
    Aug 2004
    Hi Bosse:
    If you are using the port A as digital, you will need to disable too the
    comparators.
    CM1CON0 = 0
    CM2CON0 = 0
    Greetings...
    Ruben de la Pena V.
    Sep 2006
    Thumbs up
    Thank you very much Darrel and Ruben,
    I use PM assembler. Have decided to use a ceramic resonator (20 MHz)
    Wants ALL DIGITAL if possible.
    Will try your configuration recommendations
    Thanks again
    Bosse
    Sep 2006
    Default Error in INC file
    Now I have done something ?????
    Get the error: Error 16F886.INC 15 : [201] ''' expected
    Have changed the INC file, but changed it back to original again, so now when I try to compile get this error.
    Use PM and PicBasic Pro with MicroCode Studio Pro.
    Please is there anybody how can help me solve the problem
    Bosse
    Quote Originally Posted by Bosse View Post
    Bosse
    Hi Bosse,
    Can you post your .inc file, at least the area where you been pokin' around ? Also post the first say 8 - 10 lines of the code you are trying to get to work?
    Sep 2006
    Unhappy
    Hi Joe,
    First I tries to get Config O.K. so have only a small program for testing config words. Wants ALL digital. Working with a project with MAXIMS iButton chips, works perfect with 16F88.
    ;* 16F886.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2006 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 05/26/06 *
    ;* Version : 2.47 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F88x.INC' ; PM header
    device pic16F886, xt_osc, wdt_on, mclr_on, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F886, r = dec, w = -302
    INCLUDE "P16F886.INC" ; MPASM Header
    __config _CONFIG1, _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    Think the INC file is O.K - But can not understand why it stops working????
    '@ DEVICE PIC16F886, INTOSCIO, WDT_ON,MCLR_OFF,LVP_OFF,PROTECT_OFF,BOD_OFF,CPD_OF F,IESO_OFF,FCMEN_OFF,PWRT_ON
    'DEFINE OSC 8
    OSCCON = %01110001 ' Internal 8 mhz Osc
    ANSEL = 0 ' All Digital
    ANSELH = 0
    'ADCON1 = $0F
    'ADCON0 = 0
    TRISC = 0
    RUN:
    PORTC.0 = 1
    PORTC.0 = 0
    PAUSE 1000
    goto RUN
    Do you recomend to use MPASM assembler? Have now tried more than 2 weeks with this problem.
    PORTA is reserved for furure use - PORTA.1 = Input
    PORTB %??001111 - RB6 and RB7connected to progsocket for PicKit2.
    PORTC %11100100 - RC3 = SCK - RC4 = SDA 24LC256
    Would be very great ful for all help and advices
    Thanks in advance
    Bosse
    Sep 2006
    Hi Joe,
    Forget to tell you the Warning from PicKit2.
    Warning: Some configuration words not in hex file.
    Ensure default values above right are acceptable.
    Configuration 2FF9 0700
    Bosse
    Default Re: Config problem PIC16F886
    Hi! I am using Microcode Studio version 4.0.0.0 . pbp version is 2.47 . Thanks.
    What it boils down to....
    Method one:
    Comment out the config settings in the inc file, put the actual config settings in your source code prefixed by either an @ or inside an ASM block. Use this method if you frequently change this setting or that setting a lot.
    Method two:
    Comment out the original config settings in the inc file, add in your own config settings to that same inc file in the same place. I use this method since I almost always use the PICs in the same way (i.e. HS_PLL for the 18F, MCLR on, and so on and so on)
    Method three (and others)...
    Lots of different methods for doing this sort of thing. The 2 above are the 2 that I use.
    Check the particular PICs .INC file in the MPASM directory for your particular PICs various options...
    Sep 2006
    Smile
    Hi Skimask,
    Thank you !
    Now it starts working, have changed the config in the 16F886.INC file and moved the configuration over to the real program. But still have the warning from PicKit2.
    Have to work on and make some small changes and see if the warnings will go away.
    I'm not proffessional, but have learned very much from this forum and are very greatful for all your help.
    Thank you ALL
    Bosse
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
