Puzzling issue with I2CWRITE to 24LC512
Results 1 to 5 of 5
    Dec 2007
    Paris
    Default Puzzling issue with I2CWRITE to 24LC512
    Hi everyone,
    I am getting a srtange issue when using I2CWRITE on my project. I've searched quite a bit on the net and in this forum, but couldn't find any lead on the resolution of my problem. So there it is!
    The project:
    A "robot" controller that record actions controlled by buttons/knobs and that can playback the sequence later on
    The Issue:
    There's 3 main subroutines, one for erasing the EEPROM (writing $FF using page mode), one for writing the state of button and knobs to EEPROM (recorder mode), and one for reading the data in the EEPROM (play mode).
    However, erasing the eeprom or writing data in it yields only $00 when read back...
    Troubleshooting:
    - I know that the read routine does work. I have written random data in the eeprom using an I2C programmer and could read it back perfectly
    - Writing in eeprom does indeed write $00 in memory, as verified by my I2C programmer. However, I am displaying the data being written on an LCD display just before the "I2CWRITE" instruction, and it shouldn't be $00
    - Checking with an oscilloscope, the SDA line actually contains the data I want to write.
    Hardware:
    - Based on a PIC16F877A running at 20Mhz.
    - EEPROM used is a 24LC512, with SCL and SDA respectively on RC3 and RC4 (there's no analog function on these).
    - EEPROM is wired correctly, with A0, A1, A2 and WP grounded. SDA and SDC are pulled up with 2,2k resistors, and wire lenght to the PIC is 1 cm.
    The code:
    Since code is quite long I will post only the bits that gives problem. I have used variables and not constants in each of my I2CREAD/WRITE as required.
    DEFINE OSC 20
    DEFINE LOADER_USED 1
    'Définition des broches utilisés pour l'écran LCD
    'Set LCD Data port
    DEFINE LCD_DREG PORTB
    'Set starting data bit (0 or 4) if 4-bit Bus
    Define LCD_DBIT 0
    'Set LCD Register select port
    Define LCD_RSREG PORTB
    'Set LCD Register select bit
    Define LCD_RSBIT 5
    'Set LCD Enable port
    DEFINE LCD_EREG PORTB
    'Set LCD Enable bit
    DEFINE LCD_EBIT 4
    'Set LCD Bus size
    DEFINE LCD_BITS 4
    'Set number of lines on LCD
    DEFINE LCD_LINES 2
    'Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    'Set data delay tome in us
    DEFINE LCD_DATAUS 50
    'Set ADC pins to digital operation
    ADCON1 = %10000100 'AN0, AN1 and AN3 are analog input
    CMCON = %00000111 'disabling the comparator module
    'Define pin function
    TRISA = %00001011 'RA2, RA4 et RA5 sont des sorties numériques
    TRISB = %00000000 'Tout le PORTB est en sortie numérique
    TRISC = %00100111 'RC7 et RC6 sont des sorties, RC5, RC2, RC1 et RC0 sont des entrées
    TRISD = %11111111 'Tout le PORTD est en entrée numérique
    TRISE = %00000000 'Tout le PORTE est en sortie numérique
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    'Définition du nom des broches d'I/O
    IND0 VAR PORTD.0
    IND1 VAR PORTD.1
    IND2 VAR PORTD.2
    IND3 VAR PORTD.3
    IND4 VAR PORTD.4
    IND5 VAR PORTD.5
    IND6 VAR PORTD.6
    IND7 VAR PORTD.7
    INLATCH1 VAR PORTC.5
    INLATCH2 VAR PORTC.1
    INLATCH3 VAR PORTC.2
    INLE VAR PORTC.0
    OUTD0 VAR PORTA.4
    OUTD1 VAR PORTA.5
    OUTD2 VAR PORTE.0
    OUTD3 VAR PORTE.1
    OUTD4 VAR PORTE.2
    OUTLE1 VAR PORTC.6
    OUTLE2 VAR PORTA.2
    SERVO1 VAR PORTB.7
    SERVO2 VAR PORTB.6
    SERVO3 VAR PORTB.5
    SCL VAR PORTC.3
    SDA VAR PORTC.4
    'Autres variables
    I2CADDRESS VAR WORD
    SERVO1_VALUE VAR BYTE
    SERVO2_VALUE VAR BYTE
    SERVO3_VALUE VAR BYTE
    SERVO1_VALUE_INV VAR BYTE
    SERVO2_VALUE_INV VAR BYTE
    SERVO3_VALUE_INV VAR BYTE
    i VAR BYTE 'compteur de boucle
    j VAR BYTE 'compteur de boucle
    INLATCH1_VALUE VAR BYTE
    INLATCH2_VALUE VAR BYTE
    INLATCH3_VALUE VAR BYTE
    OUTLATCH1_VALUE VAR BYTE
    OUTLATCH2_VALUE VAR BYTE
    'Alias des variables bit par bit
    REMOTE VAR INLATCH1_VALUE.bit7
    TEST VAR INLATCH1_VALUE.BIT6
    RECORD VAR INLATCH1_VALUE.BIT5
    START VAR INLATCH1_VALUE.BIT4
    STOP_RAZ VAR INLATCH1_VALUE.BIT3
    ERASE VAR INLATCH1_VALUE.BIT2
    H1GIN VAR INLATCH1_VALUE.BIT1
    H1LIN VAR INLATCH1_VALUE.BIT0
    REL1IN VAR INLATCH1_VALUE.BIT7
    REL2IN VAR INLATCH1_VALUE.BIT6
    FET1IN VAR INLATCH1_VALUE.BIT5
    FET2IN VAR INLATCH1_VALUE.BIT4
    FET3IN VAR INLATCH1_VALUE.BIT3
    FET4IN VAR INLATCH1_VALUE.BIT2
    H2GIN VAR INLATCH1_VALUE.BIT1
    H2LIN VAR INLATCH1_VALUE.BIT0
    FC1IN VAR INLATCH1_VALUE.BIT7
    FC2IN VAR INLATCH1_VALUE.BIT6
    FC3IN VAR INLATCH1_VALUE.BIT5
    FC4IN VAR INLATCH1_VALUE.Bit4
    BLANK var Byte
    BLANK = $FF
    I2CDEVICE VAR BYTE
    I2CDEVICE = $A0
    'Subroutine d'effacement
    erase_eeprom:
    LCDOUT $FE,1,"Effaceme"
    LCDOUT $FE,$C0, "nt..."
    FOR I2CADDRESS = 0 to 65535 Step 128
    I2CWRITE SDA,SCL,I2CDEVICE,I2CADDRESS,[BLANK,BLANK,BLANK,BLANK,BLANK,BLANK,BLANK,BLANK,_
    BLANK,BLANK,BLANK,BLANK,BLANK,BLANK,BLANK,BLANK],eeprom_error 'Ecriture de FF dans la page de l'EEPROM
    PAUSE 5
    NEXT I2CADDRESS
    LCDOUT $FE,1,"Memoire "
    LCDOUT $FE,$C0, "effacee"
    PAUSE 2000
    'Subroutine pour signaler une erreur de lecture ou d'écriture en mémoire
    eeprom_error:
    LCDOUT $FE,1,"Erreur m"
    LCDOUT $FE,$C0, "emoire"
    PAUSE 2000
    Now, notice that this code does actually work as it is written, but when I use this exact same subroutine (erase_eeprom) within my main code, instead of writing $FF, it does write $00!!!
    Same think with my routine that write data.
    If someone could get a lead on what's going on, this is driving me nuts!
    Jan 2006
    Istanbul
    You should post the code in which you read EEPROM back and display on LCD.
    Also, write cycle time for 24LC512 is stated to be 5ms max. in datasheet but I would make it 10ms.
    Also, if your circuit powered by less then 5V then you should slow down the lines to EEPROM.
    Dec 2007
    Paris
    Thanks for your reply!
    "Also, write cycle time for 24LC512 is stated to be 5ms max. in datasheet but I would make it 10ms."
    Yep I know, I actually used 10ms at first, even changing it to 500ms for test purposes. Doesn't make any difference: when I use the subroutine alone it always work, but not in my main program.
    My circuit is powered by regulated 5V also...
    I have attached the complete code where the I2CWRITE routines are not working. I'm still working on it so it may not be the cleanest and needs a bit of tweaking, but everything else work.
    The part of the code where I read the eeprom is the subroutine "read_mode". This is also where I added lines to output the variables to LCD for debugging (they are now removed, but it worked as I could read correct values that I programmed manually with an I2C memory programmer).
    Still investigating on my side...
    Dec 2007
    Paris
    Haha!!! got it!!
    Erratic operation lead me to think it was a software problem, but good think you takled about VCC!!
    I actually put my ajustable regulated powersupply and checked again... VCC was 7.5V!!! but everything else was working fine!
    I will have to check what's going on with my 7805, but in any case, when VCC = 5V, the EEPROM works, and i can retrieve the correct values :-)
    Well, as always it is super simple when you find it out! (took me 3 days though!!!).
    Dec 2007
    Paris
    Project is done and working perfectly!
    It certainly have helped getting your opinion.
    Many thanks!
  1. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 15:01
  2. My I2CWRITE - timings and tricks
    By FinchPJ in forum Code Examples
    Last Post: - 3rd March 2008, 22:40
  3. I2CWRITE on a 24LC512
    By oslinux in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 17:22
  4. I2CWrite issue
    By robertmark68 in forum mel PIC BASIC Pro
    Last Post: - 20th September 2006, 02:30
  5. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
