anti ESD?
Results 1 to 8 of 8
Thread: anti ESD?
    Jan 2007
    Houston, TX
    Cool ESD testing
    For what it's worth, I agree 100% with what Charles said. In college I worked on creating a HUGE ESD database for ASIC chips in a small chiphouse in Idaho. We had to of coarse qualify Military spec parts to certain MM, HBM, & CDM (Models). blah blah..
    While working in the potatoe harvesting (manufacturing equipment) industry as an intern I say my design engineer (boss) place protection to all inputs on our control boards but almost never to outputs for ESD reasons. We commonly placed a resistor, zener, cap network on all our inputs for just one reason....to IDIOT proof our boards against the assembly line. We had to gaurantee that no matter if 12V or GND -12 was connected to any input or output we would not loose a board or a PIC.
    What am I getting at???
    The PIC have ESD BUFFERS BUILT IN THEM, that's right all pins, have some kind of buffering (double diodes for example) on the inputs to protect them from ESD events. I am not sure to what levels (ex: HBM 5000V MM 2000V ?) If someone know what JEDEC standard they pass let me know I have not looked....I guess I should now that I am getting all preachy).
    Yes you can build up static on machines, hands and touching a pcb with a pic just right could burn up a port if the ESD is high enough, I would implement the 330 resistors on outputs and zeners on Vcc mentioned below if worried that much about ESD.
    I did nothing but eat, drink, sleep, think ESD for about 7 months as an intern and have not worried about it all that much with PIC's since then. Probably just a bad taste in my mouth or confidence in the designers who make PIC cores.
    stepping off soapbox now.
    Padawan-78
    xnihilo's Avatar
    xnihilo Guest
    Smile ESD protection diode for PIC I/O pin
    Hello,
    Thank you for all this information.
    I'm reading a lot of stuff on the web for 2 days already and I could not find information about the specs of the ESD protection in the PIC16F chips.
    I found a good tutorial about ESD at the DIGIKEY website and I guess it will not hurt if I use a PESD5V0LB diode on the only input pin that is in contact with the outside.
    My system is a lasergame equipment. there is a wired link between two devices through a single pin. I feel this pin has to be protected against ESD as user may touch the connectors.
    I read about the different kinds of protection and I think if I use the bidirectional protection diode as the PESD5V0L1BA it should be fine, it is like Transil or Transzorb.
    The specs of the diode are very important and I didn't find all the parameters I have to find.
    I run the PIC16F690 at 5V, 8MHz (I need this frequence for PWM, TMR0,...), with a 0.1 ceramic disc capacitor attached between VSS and VDD pins and 47UF electrolytic capacitor between power supply VDD and VSS. I'm also using ground planes.
    Should I be using a protection diode rated for 5V? I read that it should be higher or equal to voltage used for the device.
    I don't want to rely only on the PIC internal anti-esd protection...
    Aug 2008
    Using a 5V protection diode should be fine.Make sure the response time is < 1ns, ESD rating >16kV.
  1. ESD Protection
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 17th May 2007, 00:25
  2. ESD protection of input pin with Transsorb
    By Sharky in forum Off Topic
    Last Post: - 21st March 2006, 09:13
